Old 06-09-2025, 10:27 PM
See this video of Scotty at Hawkeye applying the high voltage at 1:16:00 and following.
No name is given for the device except a high voltage transformer.
https://www.youtube.com/watch?v=PFnWYe5MzrY
I also seem to recall a name attached to the handheld device you're describing, but I don't remember it, even though we had one in the lab at Zenith.
Old 06-09-2025, 10:31 PM
Is this hand held Tesla coil what you were thinking of?
https://www.arborsci.com/products/te...n=76ed39d3225f
Old 06-09-2025, 11:31 PM
Lol, beat me to it. BD-10 high frequency generator? https://www.electrotechnicproducts.c...ncy-generator/
Old 06-10-2025, 12:21 AM
Thanks. Yeah, looks like it, 'cept ours was a bit bigger and sounded like it had a mechanical interrupter driving the primary, like a Model T spark coil on steroids.
Old 06-10-2025, 12:44 AM
ppppenguin's Avatar
3 phase motors can be run from single phase supplies using variable frequency drives. Here's a random example from googling "3 phase vfd": https://www.ebay.co.uk/itm/144979535330?_ul=GB
Old 06-10-2025, 01:22 AM
Chris K Chris K is offline
Is that like a sonicator? I have 2 of them. I’m sure they won’t be applicable for this work but we use them to lyse cells. If you immerse the tip in water, the liquid will get hot. Terrible noise
Old 06-10-2025, 05:44 AM
MuzzcoVW's Avatar
MuzzcoVW MuzzcoVW is offline
Craig
Most certainly. We've installed several of these over the years where only single phase power is available. They work very well, but cost $$$
Old 06-10-2025, 08:24 AM
Hi folks. I misunderstood Jerome’s instructions regarding what and what not to post from private conversations so I removed the post, or at least scrubbed it of everything.
Old 06-10-2025, 12:17 PM
There was a quack medical device called "Violet Ray" that was a small HV operated hand held HV transformer with some kind of buzz coil in it that (it originally would drive a light up gas tube) some collectors use them to check for gas in early color CRTs (they replace the tube with a metal spike) but from having one I can tell you that some good non-gassy tubes light up just like bad known gassy ones do so it's not a spectacularly accurate test.
Originally Posted by Chris K View Post
Thanks for offering to do that. I'm hoping by October we'll have a good idea of what kind of shape the equipment is in and how good we are with manipulations. I hope we can find some guns appropriate for 10BP4 and 12LP4 tubes but since they are the oldest magnetic focus commercial CRTs, the availability of NOS guns is probably scarce.
The basic 10BP4 guns were carried through into the mid 50s when magnetic focus slowly disappeared. It should be possible to rebuild with an electrostatic focus gun and remove the focus coil from the neck area of the TV and have a usable tube....Vice versa you could add a PM or EM focus magnet and make what originally was a electrostatic focus tube work in the same set with a new magnetic focus gun.
Both the 10BP4 and 12LP4 are common enough (just about everything used them for the better part of 4 years and broadcast monitors used compatible types into the 60s) that supply shouldn't dry up any time soon (there are enough low desirability models out there with ruined cabinets as donors) but on the flip side there are many oddball screen sizes that were only used in a few sets where it a tube isn't on a shelf somewhere you might have to wait years for a replacement.
At risk of repeating myself I believe the way forward on the gun issue is to source new heater-cathode and getter assemblies and weld them to existing guns. This is what RACS did on the 15GP22 they rebuilt since a replacement gun wasn't available then. While it's a little fiddly getting grid cathode spacing right (and possibly cathode diameter) and there would be some learning curve spot welding, it's far simpler and there's far fewer variables than making a new gun and it doesn't present the challenge of requiring a maker to either find lost documents or reverse engineer an old gun.
Old 06-10-2025, 07:33 PM
NOOOO!
They did not follow up on if that rare 19vp22 made it or not! :P
Old 06-12-2025, 08:10 AM
I spoke with Nick last night (Wednesday 6/11/2025) via email. He believes current efforts should be focused on obtaining guns.
Several thread contributors have mentioned they might be able to help out with this. I guess my task is to focus on and coordinate these efforts and Nick seems ready to take it from there.
Old 07-17-2025, 01:03 PM
Just want to touch on this again so it doesn't fade away. After several email exchanges with Nick, he is sure he has the equipment functioning and will be able to rebuild, at the least, B&W CRTs. I assume this will mean 10BP4 and 12LP4 tubes for starters. The issue is guns. If you have ideas, access to or reliable sources, it would be great if you would at the least begin the process of initiating outreach. I know several folks had knowledge of available guns and said they would check quality and numbers. I have no reason to doubt Nick's sincerity and his assessment of the state of the equipment. I think we need to get him some guns!
Old 07-17-2025, 01:15 PM
Cool, but much, much bigger demand for 21FDP4s for Predictas.
Smaller diameter neck / smaller gun.
Not sure if there are more smaller or larger guns left around. When I was at the ETF last, I only saw one box of flaired neck glass for 10BP4 diameter. Over a dozen boxes of smaller diameter. Will take a detailed inventory of the guns next time I'm there.
Old 07-17-2025, 01:31 PM
Are these the disaster low voltage tubes from the Holiday model? I just sold mine for close to $2K with a bright beautiful 2.68 volt CRT. Very special I'm told to have one in like new condition. I asked for and got a price I hope reflects its rarity. Alas, I have another with a dead tube. Would any of the guns you're talking about or you know of be appropriate for the 17" Predicta tubes? I have 3 Seventeeners with very dim CRTs.
Old 07-17-2025, 01:37 PM
Yes, Holiday, Pedestal, Tandem and Continental models.
Also, many other brands used compatible CRTs - GE Coaxial, Sylvania Halolights for example. Generally speaking 21", 110 degree deflection, short neck CRTs are very much in damand. Used, strong going for around $300-$500. NOS, name your price.
The original Philco 12EAP4 was 2.35 volts. The recommend replacement 21FDP4 is the standard 6.3 VAC. I asume rebuilds would also use 6.3 volt guns.
