Old 06-30-2025, 08:01 PM
Hi - Well that cap does not look swollen to me.... But I am not there.... I would Replace
it if you think it's really swollen, but keep it, don't throw it away, and get a fair quality
tester and check it.... It's in a power area, looks like a flyback living down the street,
and parts for a switching power supply are also close neighbors.... So it's most
likely a cap that does some work, not a signal cap.... Get a replacement, and
pay attention to voltage and temp ratings.... Good Luck you are now "into it".
Old 06-30-2025, 08:06 PM
L200B L200B is offline
I tried to post the manual. I can't make it small enough to post.
Right now my biggest concern is that I don't know what kind of connectors a lot of these are. Like, if stuff is safe to just pull apart or not.
I don't want to throw this tv away.
The file size restrictions should be pretty easy to change.
Disk space on the server is a different issue. Could be a drive from 2012.
Old 07-01-2025, 06:23 AM
Probably it can be a simple fault, so patience with such complex thing is needed... and so many circuits of a such model of TV, will can prove nerve wrecking...
Old 07-28-2025, 11:37 PM
The wires that look like spark plug wires coming out of the high voltage splitter. are those made to be unplugged and plugged back in? Can I just pull them out without breaking anything?
