Old 04-22-2026, 10:23 AM
bigboss80's Avatar
bigboss80 bigboss80 is offline
I tried to measure the voltage present on pin 4 of the flyback transformer and from the diagram there should be 120 V or more because it should be the Vb, I put the negative to the negative of the frame and the positive to pin 4 and there are 128 Volts with the TV in standby and 122 Volts with the TV on but the board was disconnected from the tube, only the suction cup connected
