Old 04-24-2026, 09:02 PM
vol.2's Avatar
vol.2 vol.2 is offline
Originally Posted by bigboss80 View Post
I found a resistor R812, a fuse resistor near the line transformer which should be 1Kohm but instead with the multimeter it measures 1.4kohm, is this an acceptable value or is it out of range and could cause problems, I saw from the diagram that it is connected in series to a D806 diode which in turn is connected to G2, could it be the cause of the TV problem?
It's out of spec and should be replaced, but it is unlikely to be the problem with your set. It's 70% of spec which is almost certainly not going to bring a whole portion and the circuit to its knees.
If there is something wrong with your set that it not just the CRT tube failing, then you will probably be able to find a problem with something in the service manual. There should be voltages listed all over the place, and possibly waveforms to check with an oscilloscope. Sony was pretty good with the waveforms, and a Sam's should have them too.
First order of business is to verify all of the power supplies. TVs tend to have a bunch of supply sources taken from both the initial power supply of the sytem, and also some derived from flyback pulses. Check all of them.
Once you've done that, start checking voltages on ICs and make sure everything is correct.
Then check all the waveforms.
At some point, you'll find an issue.
Keep in mind that voltages and waveforms are specified with a specific input condition, like a color bars input or a window input, etc.
What you have displayed on the screen will change voltages in many places, and waveforms in many places.
