Old 05-06-2005, 06:39 AM
Chad Hauris's Avatar
The sams does not use a 6CM7 but calls for a 6CG7 for vert. osc/output..It may be a little different but I can probably scan it tomorrow.
Also...if the HO tube plate is not hooked up you won't get enough boost voltage to really do the job at the vert stage. You will get b+ flowing through the damper tube and the flyback but if the horizontal output is not working you won't have the AC oscillation in the flyback that gets rectified by the damper and added to the B+ to develop the boost.
Chad Hauris
