Early color television in 1967: Is it PAL or NTSC?
Here is an article from a German lifetime journal ("hobby") with the first public reactions to the introduction of color tv in 1967. It deals with PAL sets but if one didn't know that it is reporting PAL color tv system one may argue that it deals with NTSC:
How good are our color tv sets? "hobby" tests color tv 1967* The first PAL color tv sets had a color control and a tint control. The tint control regulated the white level by changing blue and red-green drive control. |
For sure, the article is talking about pal system, Germany or Europe never used the NTSC system except maybe for a few american channels (AFN Network). Late 60's, beginning of 70's, Europe countries were using various PAL and SECAM systems.
Only the real first color sets had a TINT control not to be confused with the american HUE control. The error in phase of the chroma signal did not change the color since it was constantly corrected by the "alternated line". Some sets had an automatic switching between B/W and colorcast that changed also the grid bias in order to have more natural colors (!!) (replacing the tint control). Back then even with the PAL system, colors were everything but natural. |
Grate Britan made some experimetal N.T.S.C. color broadcasting starting 1955. But it introduce P.A.L. in 1967.
I have posted this old article because it shows that reliable and natural colors didn't depend on the color tv system but on good development of the technical and electronical design of the sets. The tv sets of the first and of the second generation had this tint control. Since 1970 the tv sets only had the color control. |
tvontheporch.com |
There are some American NTSC tube sets which had a front panel control for the CRT screen grids for color balance (in addition to the phase control for chroma, which is usually called "tint" or "hue".)
The control for the color temperature, controlling the CRT screens was often called color fidelity, chromatone, or chromix. You could adjust for a "sepia tone" on b/w programs by using this control, or make the picture more blue, etc. similar to what can be done on some computer monitors. |
There were some Motorola tube color sets (TS-914,918,921)that had three color controls, the third one affecting red/blue DC balance. The way it arose was that they used a single split-pentode tube (6LE8) for the color oscillator/demodulator section.
This tube was a color oscillator operating between the cathode and grid1. This constituted an "electron-coupled oscillator", meaning that the signal was coupled to the plate by the elctron flow, but the plate circuit itself was not part of the oscillator. They injection-locked this oscillator to the burst, so no phase detector was required. The chroma signal was phase split by 90 degrees and then fed into dual screen grids, resulting in demodulated R-Y and B-Y coming off the dual plates. G-Y came off the single common screen grid! The G-Y was a bit weak for correct colors - greens tended to be desaturated and run toward brown or blue. Since the color difference signals were DC coupled to the CRT grids, imbalance in the tube's current split would run the picture toward sepia or blue-tone shadows. The more expensive sets had the third control, which adjusted the red/blue DC balance. The really cheap sets just used fixed resistors. They called this circuit the "SODPIL" - "self oscillating demodulating phase injection lock". Last edited by old_tv_nut; 06-30-2005 at 11:04 PM. |
jc |
It would be nice to have this option in modern sets ...colour television is basically artificial anyway ...imagine a stereo system with only a volume control!
____________________________ ........RGBRGBRGB ...colour my world |
Woah neat, the whole color demodulator, oscilator, was in one tube?
So what, tyhere was just the chroma amps, burst amp, and killer feeding it? |
![]() Naim amps often only have balance and source...
__________________ Make your choice, adventurous Stranger; Strike the bell and bide the danger Or wonder, till it drives you mad, What would have followed if you had |
Yep!
The earlier TS 912 had an explicit color killer stage. It worked by sensing the oscillator grid self-bias, similar to the early cheapened RCA's. Every time I see this, it makes me wonder if the oscialltor was actually free running, or a ringing circuit that died down when the burst went away. The later chassis (the picture I posted) has no stage called color killer. I haven't figured out if the function is included somewhere else, like the burst gate. Part of the problem of understanding old schematics is the number of special, multiple-winding coupling transformers used. Later sets with solid state and especially ICs made it possible to get rid of transformers and reduce costs. |
