Old 03-22-2003, 12:28 AM
"One tube lights up like a torch"
Take a look at the fourth picture down!
I can't imagine the heaters of a 5U4 being able to light that bright!?!
http://cgi.ebay.com/ws/eBayISAPI.dll...&category=3638
Old 03-22-2003, 09:23 AM
ChuckA's Avatar
ChuckA ChuckA is offline
You think maybe there's a short ?
Chuck
www.myvintagetv.com
Learn from the mistakes of others -
You can't live long enough to make them all yourself.
Old 03-24-2003, 10:06 PM
ckelly's Avatar
ckelly ckelly is offline
AK Member
is that a 40W light bulb there?
Old 03-24-2003, 10:21 PM
CarlV's Avatar
CarlV CarlV is offline
AK Member
Very impressive! Not good though.
Good Luck! Carl
Old 03-25-2003, 01:11 AM
Rob Rob is offline
Banned
Lightbulb Is this better?
Two ordinary 120 volt incandescent light bulbs. No wires hidden or otherwise.
Rob AKA Uncle Fester
Old 03-25-2003, 08:35 PM
ckelly's Avatar
AK Member
RobTV
How does one do that? I've seen pix of people with lightbulbs not hooked up to anything lit up, as well as some holding flourescent tubes.
Old 03-25-2003, 10:23 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
Damn! Those two light bulbs stimulated Fester's hair growth!
I'm surprised that 5U4 survived long enough to get a picture of it!
Charlie Trahan
Old 03-25-2003, 11:36 PM
Rob Rob is offline
Banned
Originally posted by ckelly
RobTV
Chris,
If you hold a luminous tube or lamp that contains low pressure inert or noble gas in a high voltage radio frequency field it will illuminate like a neon sign. In the case of the photo of me above the actual tungsten filaments were emitting white light from being heated to incandescence from ion bombardment of the tungsten filament. I was standing in the proximity of a large, specially constructed non-sparking Tesla coil just out of the camera's view. The field between the generator and my head was over 100,000 volts/meter. A Tesla Coil is the usual device employed to generate the HV RF field. The radio frequency energy is of a frequency too high for the human nervous system to 'feel'. That is why there is little or no shock felt during these stunts if orchestrated correctly and safely. It should be cautioned that electricity is dangerous and can kill. Such experiments as these should only be attempted by trained professionals. I used to build Tesla coils for science centers and educational institutions and can put on an interestng electricity show.
Here is another picture of the same effect with a clear 1000 watt ltungsten filament lamp showing the ionized plasma of argon gas inside the bulb. That was a heavy mouthful!
The 5U4 rectifier tube in the TV was undergoing a similar reaction but it was the 60Hz high voltage winding of the power transformer causing the gas which had apparently leaked into the old 5U4 to glow. The current flow would have been quite high and the power transformer would have started to smoke in short order from a near short circuit load.
Rob
Old 03-28-2003, 11:02 PM
ckelly's Avatar
AK Member
Rob
Thanks for the your answer - it's great to learn something new every day.
