Old 09-21-2005, 11:20 PM
Ex-Philco
If removing the damper shuts everything off and eliminates all voltage on the damper cathode, then there are no shorted caps from boost to B+. The boost is usually filtered back to B+ instead of ground. That is to use 600 volt caps instead of 1KV caps.
Have you bridged the power supply electrolytics? What are the horizontal output screen and grid drive voltages?
Don
