Old 09-29-2005, 03:16 PM
Try measuring the voltage from the wall adapter while no buttons pushed and then with a button pushed - this will tell you if you are drawing too much.
Old 09-29-2005, 10:39 PM
frenchy frenchy is offline
Frenchy
Adapter is 5.1 volts, none of the buttons make the voltage drop to less than 4.9 volts.
Old 09-30-2005, 08:30 AM
Doesn't sound like a problem with current draw. Do you have some info that 5 volts is the correct value? What batteries is it supposed to take?
Old 09-30-2005, 09:13 AM
Chad Hauris's Avatar
I think many of these old remote transmitters used a mercury battery that was 4.5 volts. Usually there is a label in the battery compartment telling what type to use so you may try to verify what voltage was needed based on battery type. Also, double check the polarity you have hooked up from the wall adapter. As I remember, the mercury battery had the negative terminal at the small tip so it went in backwards from a regular alkaline or carbon zinc cell.
Try holding the remote transmitter right up to the microphone on the set and see if you get some action. Make sure the condensor microphone "phantom power" (270 volts I believe) is present at the mic. Check all of the DC voltages through the signal path beginning at the microphone.
Chad Hauris
