Old 12-22-2005, 10:59 AM
JerryR JerryR is offline
AK Member
RCA portable, model l # 14-S-7070U
Anyone have any info about an RCA portable, model # 14-S-7070U,
picture tube number ? Would this be a good one to repair?
Thanks,
JerryR
Old 12-22-2005, 06:51 PM
El Predicta El Predicta is offline
RCA 14"
This set's challenging for a newcomer-hard to get to components!
Old 12-22-2005, 07:02 PM
Ex-Philco
Jerry:
As 50s portables go, that is definitely one of the better ones. The "U" designates UHF, somewhat rare for the period. It is well designed and constructed using a power transformer and 5U4, so the chassis is isolated from the power line. It uses a 14RP4 CRT. That's a 90 degree electrostatic focus tube. It also has a solid retrace blanking circuit and a good RCA tuner.
The 90 degree tube and power transformer will make the TV somewhat heavier than many other 14" portables of the era.
It is relatively easy to work on, particularly when compared to the later 50s RCA portables. If not already done, it will need a few paper caps replaced in the vertical and sync circuits and some tubes in the signal processing circuits. When working properly it will provide a sharp steady picture and clear, buzz-free sound. Make sure knobs and trim pieces are intact. I would not be afraid of this one.
Don
Old 12-22-2005, 09:13 PM
I would agree with Don on this one, these are nice sets.
I have two of the 7070G model, I recapped one and it has a bright, sharp picture.
The other has a bad CRT and can be a parts donor if needed.
Eric
Old 12-22-2005, 09:15 PM
Phil's Old Radios has an article on restoring one of these if you want to get an idea what you'd be getting into.
http://antiqueradio.org/rca09.htm
Old 12-23-2005, 12:29 PM
AK Member
Thanks for the info everyone.
JerryR
Old 12-23-2005, 01:45 PM
AK Member
Eric, do you have an extra handle for the top of the TV?
Thanks,
JerryR
Old 12-23-2005, 06:37 PM
No Jerry,
Every one I've ever seen was missing the handle or it was so rotted it was ready to fall off. They were made of leather or rubber nad they just didn't hold up.
Somewhere I saved a picture of one so I would know what it's supposed to look like.
Old 12-23-2005, 06:39 PM
Oh yes, here it is.
