Phil,
Your symptioms of diminishing brightness with advancing brightness control sound like either inadequate high voltage, or low B+ to the HV section. Check the B+ at hte damper. Try unpluging the high voltage capacitor, sometimes they can fail and overload the high voltage. Disconnect the CRT anode an measure the high voltage, then reconnect it and measure it as you advance the brightness. Try replacing the damepr and hv rectifier tubes. One of these things should lead you in the right deriction.
John Folsom |
replace that large resistor under the 1b3 tube. it looks as if it has been hot. if cracked it will arc. steve
I don't have any 3.3 ohm resistors in the house, but perhaps a 3.0 ohm will do here. If anyone votes for using a 4.7 ohm in place of a 3.0 ohm, speak now or forever hold your peace. That's all I've got on hand, and I don't feel like waiting 3 days to order one resistor thru the mail :-) |
Wahoo! Replacing the bad 1 meg resistor cured the arcing.
Now, on to the next problem. Thx for the advice :-) |
