Old 04-17-2006, 07:54 PM
Question RCA B&W TV KCS113A horizontal nonlinearity problem
This is my RCA B&W set from 1958, in Sam's folder 398 folder 3. Have it working well, *except* for a somewhat visible vertically oriented bighter bar up and down the middle of the screen. Caused by a small area of non-linearity in the horizontal deflection. The deflection slows down some, allowing more electrons to hit that section of phosper in the middle than in other areas (for a constant flat video image). On the back page of the folder, there is an adjustment for removing this "white line" by adjusting the Horizontal drive trim cap. This reduces it some but not eliminates it before the horizontal losses lock.
The set has been totally recapped. Any ideas? It's not too bad, but would like to improve it further.
Old 04-17-2006, 10:13 PM
Wild ideas: do you have spare HO and damper to swap in? How about resistance values from horizontal drive on through the sweep circuit? Someone here probably has more particular ideas.
Old 04-18-2006, 08:02 AM
Pete Deksnis's Avatar
15GP22 demo @ ETF 2007
"Wild ideas:"
Far be it for me to advise the forum’s design engineers, but how about ‘inverted’ Barkhausen? Might be cured by adding dark matter around the HO stage?
Old 04-18-2006, 12:03 PM
nasadowsk's Avatar
Damn does run fast…
Check the horizontal drive. It sounds like you've got a 'drive line' on the screen.
They're annoying, aren't they?
