Old 09-13-2006, 08:41 PM
Tubejunke's Avatar
The "hum" is a classic indication of a failed capacitor. I do not know what you know about electronics so I will not go into all of the details about capacitors beyond the fact that most any very old tv's need them replaced. Not ALL will be BAD but it seems to be common belief that if they are not bad then they soon will be. It is debatable in my opinion. To me its relative to how much the tv will actually be used.
Your Philco probably has several common problems. I am a Philco fan and have a 56 21" table model myself. Very dependable and simple chassis.
Old 09-14-2006, 07:30 AM
runnerben
Guest
Posts: n/a
I am still learning about electronics. I greatly thank you for the help. How do I go about checking the capacitors? I hope these are easyer to find then some parts. I searched 2 days for an ion trap magnet, and still have not had luck. Where is the best place to get them? Thanks again for the help. One more question that I forgot to post in the first one is: The socket on my picture tube is broken, I know how to replace it, But where can I find the replacement? Thanks everyone.
Old 09-14-2006, 12:43 PM
This article has basic information about identifying and replacing capacitors:
http://antiqueradio.org/recap.htm
It primarily talks about radios, but the principles are the same for TVs.
This page has links to various TV restoration case studies, which may also be helpful:
http://antiqueradio.org/restoration.htm
Replace the electrolytic capacitors first. They are critical to the power supply, and it's pointless to try diagnosing other problems until you know the power supply is healthy.
NOTE: Tube TVs have much higher voltage than old radios. Use extreme care whenever the bare chassis is powered up. A h-v shock can knock you across the workshop or kill you.
I would also replace all of the paper (and plastic-coated paper) capacitors. To check one, you need to unsolder one end of the capacitor and use a tester that applies the correct working voltage. (Checking with an ohmmeter is fairly useless, and you can't tell anything by simply looking at the cap.) It's less work to simply replace the cap without testing.
The majority of them will be bad, anyway. You can save yourself time and aggravation by replacing them now, while the chassis is on your workbench. Do not replace ceramic or mica capacitors unless you have a specific reason to believe that one is bad.
I usually check all resistors 1 megohm and higher in value, and replace any that are more than about 20% off tolerance. Smaller resistors are left alone unless, again, there's a specific reason to think that one is bad.
Be patient. TVs are more complex than old radios. There are more things to check and replace. In some circuits, it's critical to use exactly the same values for replacements.
Not to be a wet blanket, but I would not attempt this project until you get your hands on the schematic. You can doublecheck the values of components against the schematic & parts list, and check off each component as you replace it. That could help you find your way back to Kansas if you make a wiring mistake somewhere along the line.
Phil Nelson
Phil's Old Radios
