1964 Magnavox Astro-Sonic
Hi all first post in this forum. I was given a Mint 1964 Magnavox Astro-Sonic. I have a Cap Question I want to replace the power supply cap in the future don't know where I can find one its a tin can type with dual values here is what is written on the the can.
Type FP 1000 MFD 30 VDC 500 MFD 30 VSP What does the SP stand for is it AC Ron
Pioneer SX-1050 SX-980 SX-727 Teac A-3300S Pioneer PD-F1007 CDP Pioneer PL-115D JBL L46's Dayton SUB-100 Powered Subwoofer Sansui G-7700 8080 x2 AU-7700 Teac 2300S JVC QL-F4 TT Toshiba 3850 DVD SP-2700's
I think the "SP" indicates "surge" voltage rating. I would just replace with a terminal strip and some radial lead modern electrolytics.
Would anybody know where I can get a Sams Photofax or service Manual for this Magnavox Astro-Sonic Model # 1RP615 It also has the Micro-Matic model W603-18-02 Record Changer in it.
Thanks for any Help Ron
Neither number is in the Smas index - Magnavox is usually listed by chassis number, on the amp and /or tuner. Changers were usually V-M.
Thanks for the Tip I will look at the chassis.
Ron
First I want to thank you for the tip I found the chassis number on a sticker
Build Date 3/65 Chassis # R20512 00 as for the Record changer it had a sticker on the botom that says Model # W 603-18-02 Part # 523456-12 Any Help Ron
R2050100 and R2051300 are in folder 809-6 - that's probably it. It may list the folder for the changer once you find it. Here's my posting on where to find Photofacts... http://www.audiokarma.org/forums//sh...ad.php?t=82521
Tom your the man if there is any thing I can do for you Just let me know.
Big Thanks Ron
I could be wrong, but I believe that the Micro-Matic is a Maganavox version of the "COLLARO CONQUEST" changer. There's info about it here: http://mypage.iu.edu/~lrobins/collaro.htm They're supposed to be one of the best changers as I understand it, they automaticly detect record size and reject at a constant speed regardless of turntable speed. BTW, I have a AstroSonic console of similar vintage that I'd make someone a great deal on... it's currently in my dining room and has to go!
I think you are right mine does tap the edge of the record.
Ron
Let me live in the house beside the road and be a friend to man. |
You're absolutely correct, sometime in the early 60's or late 50's Magnavox bought Collaro. The early ones sensed record size by a small finger that was located just to the left of the balance arm. Then they came out with the changer that the tone arm tapped the edge of the record to sense the size of the record, the tone arm sits down on the record about 1/4 inch in from where it was stopped, so if you came up with an 8 1/2 inch record it could play it just fine.
Around 1970 they cheapened up the changer and eliminated the second drive wheel that ran the changer mechanism. This changer still senses the size by tapping the record but the cycling cam has three grooves for 7, 10, and 12 inch records and arm sets down according to which groove is lined up by the record tap. On these changers the changer mechanism is ran off a gear around the center turntable bearing. IMHO the early ones that sense record size by tapping the edge of the record and have a separate idler/drive wheel running directly off the motor are just about the best record changer used of the period. Very early Magnavox's before Collaro used Webster-Chicago and a few portables can be found with VM changers. There is a rare portable that uses the RCA 45 RPM changer. I wish I had a dollar for every one of these changers I've worked on, about the only problems we had was due to hardened grease and dirt causing bearings and pivot points to lockup, and idler wheels. I bought all the Magnavox service manuals from my former employer when he retired and closed up shop so I'm pretty well stocked up on service manuals if anyone needs a copy of one. Quote:
"proximo satis pro administratio" KAØSCR |
I could sure use one for my 1965 Astrosonic the model and chassie number I gave earler in the thread post #6
Thanks Ron
Send me a PM with your address......
Randy set me up with the Collaro literature that he has, and I cured the intermittent "NO REJECT" problems that my 1962 Maggie console had. It was all due to dried up lube. It works great.
Playing a load of 78's these days. Bruce |
