Old 11-30-2006, 06:52 AM
jstout66 jstout66 is offline
oops... His last name is Hauris. He's in Midland.
Old 01-08-2007, 10:14 PM
fujifrontier's Avatar
fujifrontier fujifrontier is offline
roundie not so n00b
OK. Does anyone have a SAMS for this set? I want to get it off the front porch and back to life.
Originally Posted by TVTeufel
Another idea.....instead of expensive anti-psychotic drugs, let's provide schizophrenics with dummy bluetooth headsets. They'll easily blend into the crowd, although I suspect their "conversations" would be far more rational than those of the typical Wal-Mart shopper.
Ron
Old 01-08-2007, 10:25 PM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
If someone here doesn't speak up, you can get one directly from sams technical publishing
http://www.samswebsite.com/cart/cart...o=pf&id=132187
bout 15 bucks plus shipping.
Get yourself a good variable temperature soldering station, a variac, solder vacuum or wick, some 60/40 rosin core solder, and a good work bench to prop the chassis up on while you work.
Get your caps from justradios.com I was recommended to them from members here and have not been disappointed by pricing and service.
Personally, I would just talk to Chad Hauris. He's worth the drive to get this set done quickly. He can help you out. You can tackle this one, but if this is your first and you want it done the right way the first time, take it to a pro
Jordan
Old 01-09-2007, 01:02 AM
roundie not so n00b
oops :P i feel silly now.
Which one should I buy, 639U or 639? Mine is the "Super" with Teletimer
Ron
Old 01-09-2007, 07:58 AM
polaraman's Avatar
polaraman polaraman is offline
<--1956 300B
I just happen to have the factory service manual for your set. Trade you a copy for your set? PM me with your address and I will send you a copy.
polaraman
On the Bench: Master's Degree Thesis!
Old 01-09-2007, 07:08 PM
roundie not so n00b
http://www.radioshack.com/product/in...entPage=search
soldering station?
http://www.radioshack.com/search/ind...rosin%20solder
solder
solder vac
is that stuff OK? and $250 for a variac? HA!
Ron
Old 01-09-2007, 08:02 PM
jpdylon's Avatar
pass on that soldering station. Check out MCM electronics or parts express and get a good Weller temperature controlled solder station. They last forever and are well worth the money.
Jordan
Old 01-09-2007, 08:45 PM
roundie not so n00b
http://www.partsexpress.com/pe/pshow...36&rak=372-120
this one?
and polaraman, which one would list the parts that I need? the service manual or the SAMS? I've seen some stuff in the service manuals and it all seems kinda scary. How many caps does the average old TV like this have, that need to be replaced?
Ron
Old 01-09-2007, 08:58 PM
jpdylon's Avatar
that would be ok for most projects. However you may want something in the 50-80 watt range for the big filter caps, or grounding parts of the chassis that easily absorb heat.
Average caps can be from 20-50 paper depending on the TV.
Jordan
Old 01-09-2007, 09:22 PM
blue_lateral's Avatar
Weller WTCPT. These things are the bomb.
I think it used to be called WTCPS, if you see used ones on Ebay or whatever.
John
Old 01-09-2007, 09:40 PM
Yep. That's what the techs at work have. Weller. Don't even fool w/anything else.
Old 01-09-2007, 09:53 PM
Old 01-09-2007, 10:52 PM
roundie not so n00b
hmm... which will show me the parts i will need to recap the set, service diagram or sams?
Ron
Old 01-11-2007, 05:11 PM
roundie not so n00b
Bump
Ron
Old 01-11-2007, 09:27 PM
Tubejunke's Avatar
You need a Sams folder! It lists and picture points every component. The lists show component values, replacement part#s, and some cross reference. I now find them to be very necessary and covienient for making parts order lists.
