If the top cap is still connected but loose, some super glue will fix. If the cap is off, scrape the existing wire sticking out all around to make it bright, take a thin copper wire and wrap a couple turns around it, touch it FAST with soldering iron & solder. Being quick avoids breaking the tube. Heat the separated cap so that the hole in the top opens. Glue it back on with the wire sticking out, and solder the wire FAST. Usually can fix them this way.
The 80 will be kind of pricey, and the 45 really so. If it's too much, there are ways to substitute other tubes using an adapter, which is much less money, but not so "pretty."
80s (5Y3GTs with the correct 4-pin base) were not that expensive a few years ago, and I guess plenty of people have a few they would let go for little money. Good luck. |
would a 4 pin 5Z3 work as I have one?
#1 (2)ADS L1090,(4)L300e,(2)SW2,B&K AVP4090,Carver AV-806X,Sony Blue Ray,50" Samsung LCD #2 (2)Soliloquy 6.5,(2)Primaluna Prologue 7,First Sound Presence Deluxe,Music Hall DAC 25.2,Music Hall Maverick SACD,EeePC,PS Audio Xstream Bi-amp #3 DilithiumCrystalMindMeld |
No, unless the filament winding in the power transformer is overdesigned.
The 80 has a 2-A filament current, while the 5Z3 needs 3-A, so it would most likely overload the transformer. You can grab the 4-pin base from the old 80, add an octal socket with 4 pieces of wire and make an adapter to use a 5Y3GT. I think this is the best possible thing next to an actual 80. Good luck. |
Dad says he wants to keep the radio stock rather than modify. He says he can listen to another radio...
Since this radio is totally original, I can see his point. Looks cool on the shelf!
Replacement of worn parts is normal in the life of a radio. I don't think anybody
advocated modifying the radio, plugging in a tube substitute is just a cost saving measure. But it's your dad's radio... P.S.: if the radio was totally original, it wouldn't be missing tubes. Good night. Last edited by electroking; 07-18-2010 at 07:07 PM. Reason: added note |
That's probably the correct speaker for your Swan. I've seen them with Lansing, Magnavox, Rola and others. They seemed to use what was at hand. They also had a couple different types of chassis as they made the swan for 2 years.
I have one with a Rola speaker and I just finished the chassis a couple weeks back (here's a photo). My cabinet needs work and the speaker needs a recone. You have a very nice radio. Good luck with the restoration. |
