I have TWO of these to repair...but no longer wanna bother with 'em since I have a running 1020, 1030 and CT101.
I didn't even wanna bother the guy offering the 1010 schematics....or I'd try to get back into the 1010 and then have to repair the ribbon cables as well as whatever had happened to them in the first place. I do have the small sets to "wow" anyone if need be. That 1030 is actually QUITE a handsome little set...and is smaller than ALL the other Travelvision sets.
My current "holy grail" is trying to get enough parts together to get a Singer TV6U going. Been kicking my ass for nearly a year now :-P |
but it would be a good thing to know how to fix them should they take a dump, afterall they are old and i think that whatever kind of vintage tv you may have its always a good idea to know how to fix them. and the ribbon is not all that bad to fix as mine tore in 2.
Did the diode replacement correct the horizontal, or did you replace the AN5750 too?
Dunno.....ALL of the little TRs use the same one with the funny little squared off tip. I thought it was 7.5v unit....but could be entirely wrong. Almost positive it is NOT 12vdc though...or I would not have gone through the trouble to find the exact one when I needed one. If you are using a 12v one.....you are likely gonna cook the regulator. The battery pack is 4 x AA size batteries...so the set likely runs at 6v internally without looking at a schematic, so I'm still guessing the wall wart is gonna be 7.5vdc.
UPDATE: Found one of mine specific to the set. It's part number (Panasonic) TY-AC39P Input is AC 120V 60Hz 55mA Output is 11.45vdc (positive tip) as measured by a Fluke meter (no load) There is no output specs printed on the outside of it. I even found a second one that is running my 1020....same exact model and specs. Looks like all three of the little TR series use the exact same one. I don't have the CT101 down here at home to look at (It's up at my Dad's house)
My current "holy grail" is trying to get enough parts together to get a Singer TV6U going. Been kicking my ass for nearly a year now :-P Last edited by AiboPet; 11-13-2012 at 07:25 PM. |
Benevolent Despot |
well here it is i still got a line across the screen and checked all voltages and seem just about right on and still cant figure why i just have a line. replaced both horiz and verticle ics and made no difference at all. this is baffling to me finding nothing else wrong but i know there is something. caps were changed checked diodes only to fine the one, i also took off some resistors and transistors to check out of the circuit and everything checks ok. and yes these components are SMD, chips very difficult to see let alone remove and put back. did anyone who reads this post have any info as to where to go from here with this problem. it seems to be a common problem with these little sets. HELP.........
well this update means i gave up on this tr 1010p, checked everything and waisted to much time. i got another one, tr1020 with the radio and it had the same line across the screen but i fixed this one and it works great. the circuit board is different and i think for the worse, anyway caps and ics were all loose all had to be resoldered and 2 breaks in the ribbon which i had to put 2 jumpers. it looks like vibration did all this from years of bumping around.
Good job with the TR-1020p. Be aware that they are almost as bad as the TR-1010p electronically. You have now officially been inducted into the "TR-1010p Kicked Our Ass Club"!
the board is different from the 1010 to the 1020 alittle easier still very tight.
LOL!!.....I been to that club TWICE now. I'll go back sometime when I need another good ass-kickin' :-P
I love the little 1030, and the one I have has not been opened yet. I saw no reason to so far. It's smaller than the rest of the little TR sets, so I'm sorta afraid to ever open it. I have a 1020 that also just needed some soldering touched up before it would keep a full raster. Works great....but I need to find a battery cover and it's magnifier. ALL the little TR set's have different magnifiers....not interchangeable.
My current "holy grail" is trying to get enough parts together to get a Singer TV6U going. Been kicking my ass for nearly a year now :-P Last edited by AiboPet; 11-20-2012 at 04:58 PM. |
does your 1030 work? and how good compared to the 1010 would you say it is.
The TR-1030p is electronically superior to the previous models, but it folds into a 3 sided square that is held together by a 10 pin soldered connector at the end of a very similar ribbon cable.
