Thanks! Yeah, it was by pure happenstance that Danny found this one. It was at a sale he originally wasn't going to go to, but he decided to check it anyway since he was in the area. I already know exactly where this set will go, too. It will be a lot of work to accomodate it, but it will be worth it. This set does indeed have an Admiral built chassis. So that's really neat. I suppose I should change my signature, huh?
Quality vintage television service by Alabama's original Animegao Kigurumi performer. Last edited by TUD1; 03-12-2017 at 06:54 PM. |
Hell no. Why stop at one?
Nice looking set. You'll soon discover that having only one isn't enough, space permitting.
Quality vintage television service by Alabama's original Animegao Kigurumi performer. |
Here is a picture of the Admiral TV chassis.
The first generation Admiral chassis. IIRC, they made it for two years. They even made a rectangular set, with that chassis. The color circuit was an RCA design. The next models were cheapened and used the 6LE8 type color circuit. They even made a roundie with the newer chassis, BOTL.
![]() The amplifier in your set is respectable. It's amazing how good the SE 6BQ5's sound. |
Also do we have any information on this seemingly generic RE21FJP22?
I could be mistaken but it looks like 0479 is stamped in red over the green print on the label. Would that be a rebuild date of April 1979?
I already knew that. Sorry. What I meant was do we know who made it or if it's original to the set? AEI kind of sounds like Admiral Electronics I????
Tube is a rebuild. Perhaps a rebuild from a local company?
At one time, Omaha had a handful of picture tube rebuilders, so I wonder if there was a local rebuilder in the area this set was found? |
Yeah, Danny did say it was a rebuild. I just remembered that. Here is a picture of the AM/FM stereo. Interestingly enough, the "Pull on push off" treble control is just a standard turn-click switch. Oops.
I've watched every single cataract video on Youtube about five times each. I'm going to practice on a couple of junk tubes before going to the real deal. One with the water method and one with the heat.
Someone could have easily replaced the pull on push off switch with a conventional twist on switch. The twist on switches were a lot easier to come by than the pull on push off switches.
