I re-dressed and re-soldered on the plate cap clips for the 1B3GT and the 6BQ6GT tubes in the HV cage. I made sure there were sharp points. The reason I did this was the plate cap for the 6BQ6GT had fallen off. The wire strands were broken. The plate cap for the 1B3GT was hanging on by just a couple of strands.
My E-Cap order came in so I finished up re-stuffing them. Each can holds 3 E-Caps. I used Nichicon slender caps where I can. Each can was able to hold the 3 caps next to each other. No stacking. I use hot glue to glue the 3 caps together with the negative leads close to each other. I then connect the negative leads together and use some solid 22awg 600V wire for the leads. I attached them using the coil method. I then form each lead to make up a bundle coming out from the approx. center. This bundle is laced tied to give it some extra strength. The leads are trimmed and stripped before I insert the caps into the sleeve.
A generous bead of hot glue is placed around the bundle then it is inserted through a 5/32 hole drilled in the bottom. The assembly is held in place till the hot glue sets up. Then the caps are tacked to the wall of the plastic sleeve. The leads are soldered to the contacts. The ground lead is left unattached. It will be connected to the can after it is inserted into the chassis. I place the cans back into the proper position into the chassis. I then solder the "twist" tabs to the chassis. I'm afraid that they will break off if I twist them. Then the ground lead is attached to one of the tabs soldered to the chassis. When all done, I'll slide the cans over each assembly to finish off the chassis. ![]() ![]() ![]() ![]() ![]()
I got some more done on the chassis recapping.
I changed out the cap "C46" and resistor "R62"on the "Contrast" and "Horizontal Hold" control. I then began recapping and rewiring the fuse and selenium rectifier. I'm using a terminal strip for each. I'm using pigtail fuses. For the rectifier, I'll wire the original selenium in then get some voltage measurements, then change it out for a 1N4007 diode. Then I'll adjust the existing 22 ohm resistor "R77" to match the correct voltage needed. I'm needing my .2uf 630v caps from Just Radios to really get into recapping. The caps are "layered" and I'm not going to do much till I have all the caps on hand. There is some that I can do though. Just a limited amount. I also changed out another cap "C54" and one of the heat stressed resistors "R77". ![]() ![]() ![]() ![]()
Have you verified that everything in the Horizontal hold circuit is good?
Could you be more specific as to what you mean by good? I replaced all the caps and resistors in the circuit. I have will go back and check to see if I made a mistake replacing those caps and resistors.
My friend emailed and said to turn the H. Frequency adjustment CCW. It has a wide range. Bingo.
I'll have to put in the 16KP4 tube next to see what it'll really look like.
This morning I removed the focus coil off the test CRT. Much better. I'll do some voltage checks and replace the selenium rectifier today. The picture is actually much better in person than the photo.
Getting better. Here is small clip from White Christmas. With the 16" CRT.
https://youtu.be/5KVM0_c8l4Q |
Wow, top notch work!!
OK, I aligned the video and sound IF using my signal generator and VTVM. I have a good picture and great audio.
I do have some little white bars that go across the top of the screen. See attached picture. Any ideas?
Those white lines are very likely from your video source.
They are either closed captioning (which lurks at the extreme top of the frame), or macrovision copy protection (which usually droops down lower).
If you have Cable/Satellite you should watch the AMC channel on your AMC TV set at least once.
Still looking for some information about hooking up a frequency meter to measure the Horizontal Frequency of 15750 cps. Has anybody done this?
Thanks. |
I've got the test pattern looking pretty good. There is a "ghost like" squiggle on the right side. I haven't played a DVD yet but I will.
That squiggle looks like a bit of H. retrace. See if it'll go away by reducing the brightness a bit.
Linearity that good (both H and V) is seldom seen on a vintage set. The quality of your resto would do a seasoned techie proud. |
