May not be any daytime AM, but there should be some decent stations at night....I've regularly been able to tune AM stations from better than half way across the continent at night.
I don't know what to expect with short wave up there, but if somewhat close to the east coast there should be plenty of European stations.
Soon enough I'll clean the crud off the front of the dial glass (I won't attempt the back) and take it to where I can scan it, just in case. I'll scan the original documentation as well. Quote:
Hmm... get a small crappy portable fm radio and inject that into this radio.
Would it be possible to align the FM radio for use with the Pye's tuner? I've been checking the values of AM/FM gang capacitors and they seem to be very similar. Also, I was watching a video by a fellow who made an FM converter that uses an antique radio's existing tuner but it's all in Italian as is his site.
Another option is to look for a Pilot FM tuner and hook that to it.
https://www.youtube.com/watch?v=VVo0AXA4IUc Ultimately this sort of thing is what I would like to do, a totally reversible "barely there" modification. I was thinking I might be able to do it with a modified automotive FM converter, but then MadMan mentioned the FM portable radio which would be much easier to get my hands on. |
That Italian guy's converter box is pretty neat though.
What Tom said makes sense, link the tuner shaft to the tuner of a little fm radio. You could use an o-ring, or similar rubber belt, maybe. If you get it tensioned, turning the tuner will turn the fm tuner also, but it can slip too, providing for the difference between the two tuners. Better yet, get an fm radio with a digital tuner, and rig it to tune with a rotary encoder switch, and belt THAT to the tuner shaft. |
By the way I got the dial glass cleaned up. It was pretty filthy on the back too so after a quick test to make sure a light wipe with glass cleaner wouldn't damage the printing I just went to town on it and now it looks great. Last edited by Jon A.; 10-29-2017 at 06:13 AM. |
Any update on this project?
Nope, the now former owner balked at the cost to restore it and left it here. I have no idea what I'll end up doing with it.
Isn'"t that always the case! This is why I don't usually like doing work on vintage electronics for other people. I recently restored an old early fifties Goodmans hifi speaker from England, and it made me think about your radio. The last time I even touched a British radio was over 20 years ago, and that was a repair I did for a family friend. I've been collecting vintage radios here in Alberta since the early 1990s, and have never come across anything from the UK except some rather large transistor radios from the 1960s.
Well, this radio is of a British design but made in Canada; same dif I guess. I'm guessing only final assembly was done at the Ajax plant; I noticed that some components were stamped "Made in Britain" or something like that. I have a tuner board I could probably modify to work with it, that is if the right person shows interest. |
Eh, probably just the typical copy/paste fail.
