the 2nd gives the plate bias to the 1st not sure what it is yet, Remember i have a CTC-16-XL. almost the same as the 16, but different in quite a few ways.
Right now I am very suspicious of c12 ( c21 on the CTC-16 version ) , if that was leaky that may cause what I am seeing.
when i get around to pulling the chassis to try and fix this, i will most likely replace all the.001 caps
on a unrelated note, I took a nibbler tool to my HV cage, to add even more airflow, this is the thermal scan after 15 min, w/o the fans.
https://imgur.com/XSifzsf
Does anyone know why the second IF stage is "floated" above ground by about 150V? Is it an effort for using the second IF stage as a voltage drop to provide plate voltage for the first IF stage? Kind of like the audio output tube circuit in some B&W sets to provide an approx 140 volts source at its cathode. I see where RCA used this arrangement for many different models.
If the AGC were way off, the second IF could be biased such that the voltages for both the first and second IF could be way off. Go back and check the voltages on the first IF stage as well. There is a good chance they are off as well. Last edited by Tom9589; 10-05-2019 at 10:41 AM. |
even with 1st IF removed the cathode voltage was gone. I can see WHAT is happening, but since I was probing with tube test sockets, it don't know why yet. with 1st IF removed, should i not see 160v ( approx) on the cathode of the 2nd? I'm just going to have to make time at some date to take it all apart and check all resistors / caps in the area again.
another thing that may explain what i am seeing, this is doing EXACTLY what it did before i replaced R48 & R50, i put in 1/2 watt carbon film ones, it said to use 1/2 watt, perhaps they did not hold up, perhaps it's time to replace every resistor off that power line with 1 watt resistors. ( and the .001 caps )
EDIT- It's looking more and more like that is what the problem is, seeing a good 300+ v at point 3, and on the far side of R51 getting power to the plate of 2nd IF. But there is crap at point 14 other side of R50, hardly 30v. Time to change it again with a 1w and the filter caps.
=^-^= Yasashii yoru ni hitori utau uta. Asu wa kimi to utaou. Yume no tsubasa ni notte. いとおしい人のために Last edited by Yamamaya42; 10-05-2019 at 01:49 PM. |
Those .001 wax ceramic ELMENCO caps I have heard are usually either bad or going to go bad soon..
Honey, turn on the tv.. I'm cold! |
I always thought those tube cap things were funny looking, but i never thought they would cause this much trouble :/
The elmenco caps .001 and up are just wax caps in disguise.
I'm guessing that this will be a good replacement for them.
667-ECQ-E10102KFB (mouser ) I'm in no big hurry to get IF working again, as it's working OK via video input, I will most likely wait till it gets cooler.
Those caps are the usual caps if you want 1 kV, very reliable.
BUT ... why the "B" on the end???? That's NOT usual, as it means a crimp in the leads. Normally for old sets one leaves the B off. And saves a couple of cents. |
I did not even know I had this...
https://imgur.com/7rYdtgs playing one of the " The Prisoner " laser discs, I let it run past the end of the credits on the 2nd disc and saw this was there ![]() never know it was there. It's still hard to get a decent picture, it looks better than this :/ "BUT ... why the "B" on the end???? That's NOT usual, as it means a crimp in the leads." ( ref to prev post) true, i don't really need the crimped ones.
I guess while I'm in there later, ( with the bottom shield of the IF off) I will replace the 2 detector diodes, (1N60), not that they are bad now, but I hear that they do wear out, and I would rather do it now than later.
That test pattern looks good! That's with injected IF?
