Old 12-12-2021, 01:22 PM
If it uses the same 30s 5-pin socket/base as a type 76 tube (common speaker plug into the octal era) then it is in a way keyed such that it only plugs in one way. There's 4 pins closely clustered and a 5th pin off a ways....pin spacing is not symmetrical in both axes so it will only plug in one way (unless you break it).
Well that's the thing the plug coming out of the radio itself is broken, it's broken on one of the sides that has the close together pins.
But I think though that more than likely it's the hum bucking coil, that's bad, like I already suggested, I was just throwing that out there as an alternative idea.
Old 12-12-2021, 06:55 PM
You could try bypassing the bucking coil or reversing the leads and see if hum improves.
Old 12-12-2021, 07:06 PM
How would I do that? Which wires go to the hum bucking coil? I'm asking because I don't want to accidentally cut the wrong wires.
Old 12-12-2021, 09:11 PM
I'm guessing the hum bucking coil is the black and white wires coming out of the coil on the back of the speaker shown in the picture below?
Old 12-13-2021, 12:34 AM
OK, so a little update, I removed the original speaker from the cabinet and replaced the original speaker plug with the one from my parts unit, and hooked the original speaker up to the radio with it outside the cabinet and no hum! So was it maybe something weird with the old speaker plug and something weird with the cabinet?
Old 12-13-2021, 03:51 PM
[QUOTE=vortalexfan;3238193]I'm guessing the hum bucking coil is the black and white wires coming out of the coil on the back of the speaker shown in the picture below?[/Q
I'm not familiar with that radio, but I'd guess the black and white wires are L16( the speaker field). The humbucking coil is a separate coil(likely sandwiched to one end of L16), that is wired in series with the voice coil. Reversing the field could have the same result as reversing the hum bucking coil, resulting in more hum. The way to figure that out is to try reversing it. Whichever way produces less hum is correct.
Old 12-13-2021, 04:15 PM
[QUOTE=Kevin Kuehn;3238202]
Ok, so I'm not sure what would be different between the speaker being in the cabinet and out of the cabinet but with the speaker out of the cabinet the hum is non-existent, and I'm not sure if this would of affected it or not but I did replace the old broken speaker plug.
