Old 10-19-2023, 09:52 AM
Not really, other than improved HV creepage and clearance handling perhaps, the specialty 66m 6kv resistor will do fine as it was made for just that application, the only reason that early color sets had 3 22m resistors was that they had not created the specialty 66m one at the time and was not in mass production as it was later.
the 1963 silvertone I had with the ctc12 clone had the stick resistor unless Motorola decided to keep using 3 resistors maybe they didn’t trust the new stick resistor.
Old 10-19-2023, 06:45 PM
Or they just had a HUGE stock of 22m 6k resistors on hand!
Old 10-19-2023, 08:05 PM
Or, at the time, they could buy three 22M for less than one 66M.
Old 10-19-2023, 06:44 PM
did you ever do the heater voltage tests?
Old 10-20-2023, 09:06 AM
I didn’t do the heater voltage test yet
Old 10-29-2023, 07:59 PM
Zenith 21FJP22 tubes
Years ago in working with Zenith TV's I came across a Zenith roundie with a CRT that had a Zenith brand sticker/label on the top of a RCA label. They were either too lazy or didn't care.
julian
Old 11-06-2023, 09:36 AM
Gun booster
Anyone know how these work I have used one in the past but don’t know how this works by boosting the gun but does not change heater voltage. They do work good without changing the heater voltage.
File Type: jpeg 24754966-7DA8-4E7F-B960-769BC7882FE7.jpeg (61.0 KB, 19 views)
Old 11-06-2023, 10:35 AM
Are you sure? I can't imagine how that's possible.
Old 11-06-2023, 10:50 AM
I did post the same question years ago but don’t remember the result. I think it was taking voltage from somewhere else within the plug there is an adjusting pot and no transformer inside since I took one apart befor and all there is inside is a resistor and a pot.
Old 11-06-2023, 11:39 AM
I'm not sure which one you got and opened, but the way that most work is on 2 levels, first is by boosting heater voltage from 6.3 to at least a volt or more higher via a transformer in most cases, second is by isolation which may sometimes help in H-K shorts.
Old 11-06-2023, 11:43 AM
These brighteners came red green and blue depending on what gun is weak the pic is for the red gun they are colored. I had taken a green one apart and the heater connection is not touched at all just wires from the gun that will be boosted to a resistor and a pot that’s it
Old 11-06-2023, 03:14 PM
It has a pot that is accessible for adjustment (not visible in the photo)? Must be changing the G2 range on the affected gun.
Old 11-06-2023, 01:10 PM
I'm unfamiliar with how those type might work, never having seen one, they must be trying to alter the bias of the “weak” gun in relation to the others to try and balance things out, but I can't imagine that working out so well vs a real booster that kicks up the heater voltage, which is only a Band-Aid to start with.
Old 11-06-2023, 01:47 PM
I used one on another set with a really weak red gun could not get a white screen not enough red but after plugging one of these in it never changed the green and blue adjustment only the red just turned the pot up alittle and viola had more the enough of red. It is odd not to increase the heater voltage but it don’t but they do work well.
Old 11-06-2023, 03:16 PM
The only thing I think it may have been doing is altering the cathode bias beyond the standard ranges on the tube for the weak gun, and thus pushing the drive level even harder, but that can't be very good for a weak gun on a tube, likely to burn it up fast.
