Old 02-09-2011, 10:22 PM
Originally Posted by rca2000 View Post
So, another way to describe the HOT ckt would be like a "switching power supply", I reckon, and class "C" is not too far off.
As we know, in an SMPS, the switch transistors must be on or off, and nOT much in between..or WAY too much current--and then destruction--immediately follows.
Old 02-09-2011, 11:07 PM
mbates14 mbates14 is offline
oh yea. ive had my fun building DIY SMPS circuits. WEEEEEEE
especially when your not pushing the gates hard enough, you power up your circuit, works for a little bit then... KERRRPLOWWWWWW
weee yea what fun....
Old 02-10-2011, 05:32 AM
trojanrabbit trojanrabbit is offline
Of course a flyback is a type of switching power supply (having designed a couple).
And sweep tubes were commonly used in lower cost amateur SW transmitters, probably running pretty close to Class C (I think you could get 100W PEP SSB out of a 6JE6). You tuned the final to minimum current.
Old 02-10-2011, 12:14 PM
Kevin Kuehn's Avatar
Workin' Late Again
The HOT under normal operation is either on hard, so the voltage across it is low when current is flowing; or it is completely off, so the current is zero while the voltage is high. Therefore , the power dissipated is low, because the product of (voltage x current) is low or zero. Without the drive waveform, it can be somewhere in between - this condition of having both current and voltage means that the power dissipated in the HOT goes up drastically.
I don't see a problem with installing a bypassed cathode resisitor to limit plate current, in the event of drive signal loss. My mid 50's RCA B&W has this. But a lot of TV's don't have it. Were they too cheap to spring for a resistor and cap? What am I missing?
Kevin
Old 02-10-2011, 04:19 PM
miniman82's Avatar
First Light: 1952-2011
Perhaps the added cost was not justified? I read that one resistor was saved in the matrix of the 21CT55, vs the CT-100. You might be surprised the lengths OEMs go to for cost reduction; some of it borders on a safety risk, especially with cars.
Evolution...
Old 02-10-2011, 04:26 PM
John Folsom's Avatar
The resistor elimination in the 21CT55 matrix from the CT100 design was a patent dodge. RCA did not want to pay royalties on I/Q demodulation. Well, thats the story I heard. RCA was known to do almost anything to avoid paying royalties.
John Folsom
Old 02-10-2011, 05:17 PM
Pete Deksnis's Avatar
15GP22 demo @ ETF 2007
John. I came to the same conclusion recently. The quadrature transformers for the CTC2 and CTC2B chassis have different part numbers. They would have to be since the demodulation angle is different for R-Y demodulation than it is for I demodulation,
I do not have a CTC2B chassis to test my theory, but one must rule
out the possibility that the CTC2B chassis does not properly decode the color signal transmitted by an NTSC broadcast transmitter. The two color signals, I and Q, that are trasnmitted by NTSC standards are in quadrature. In the CTC2B the decoded chroma, Q and R-Y, are not. When a quadrature signal is encoded, it must be deconded in quadrature if crosstalk is to be minimized.
If I am right, the CTC2B chassis is inferior to the CTC2 chassis when decoding an NTSC broadcast.
Now, it is always possible that some stone has been left unturned by me. Perhaps eliminating the one insignificant-in-cost resistor in the CTC2B matrix somehow negates the not-in-quadrature problem. I don't know.
BTW: I believe it was probably Philco that RCA was dodging.
Pete
Old 02-26-2011, 05:08 PM
Tomcomm's Avatar
Tomcomm Tomcomm is offline
Comparisons before and after FBX replacement.
Here are preliminary comparisons of the original FBX vs the replacement FBX installed in my 21CT55. The screen is still too wide, must be the original yoke is more sensitive then the newer yokes intended to be driven by the replacement FBX. No, I wont try to find a newer yoke………..Tom
Old 02-26-2011, 05:19 PM
Steve McVoy's Avatar
When I had to come up with a flyback for my CBS field sequential color adapter (the original was missing) I had to experiment with various things to get the replacement to work with the yoke. I also had too much width. I added an inductor paralleled by a resistor in series with the yoke. Maybe something similar would work for you:
http://www.earlytelevision.org/cbs_c...storation.html
Old 02-28-2011, 02:28 PM
Tomcomm's Avatar
Hobble-up Width Control
Steve, thanks for your interest in my 21CT55 reactivation. The new FBX is very efficient, delivering 32kv maximum ultor and 800v boost with B++ of 398v. Fuse current is same as HOT cathode and runs at only 174ma. B++ is limited with power resistors in the power xformer hv secondary so I can select three B++ voltages with 115vac input from my Variac: Low is 374v @ 160ma HOT, Med is 395v @ 170ma HOT, High is 420v @ 182ma HOT. After running for 3 hours at Med, FBX is bearly warm at B++ of 395v. Excessive screen width is the only major problem. All RCA's CTC7 and above have no width control. They must rely on tight spec'd parts in the Horz/EHV system to give just the right over-scan.
Your experience with using inductors to load the FBX and bleed-off drive to the yoke is consistent with my Fink '57 TV engineering handbook descriptions of width controls . Most of them were shunt where yours is series dropping. I intend to try various schemes to pull mine in.
The preliminary pics I posted above were somewhat disappointing to me. I definitely have chroma leakage in the Q channel since I don't have the proper output filter values installed. Also my camera was on AUTO and bad focus. Here's some full manual pics. The first pic is a stitch of extreme crop of new vs Sony Pro. Q chroma leakage is obvious:
File Type: jpg Copy of Chopped close up RCA Sony 1..jpg (78.4 KB, 63 views)
Old 02-28-2011, 03:03 PM
miniman82's Avatar
My 7 and 9 both have a plug on the yoke you can move around to get the desired width, while my 4 has an actual switch.
Evolution...
Old 02-28-2011, 05:03 PM
sampson159's Avatar
sampson159
my 9 has that plug also.these sets produce some of the most pleasing colors.i have it along side of my zenith space command and the 9 s flesh tones are remarkable.my xl100 and the zenith chromacolor with the 25vdmp22 are better,but not that much.love those old rcas!
Old 02-28-2011, 08:26 PM
What are the other 4 pics? Chroma dots on every other one? - like with and without 3.58 trap in the luma.
Old 03-06-2011, 02:33 AM
cbenham's Avatar
cbenham cbenham is offline
Originally Posted by trojanrabbit View Post
Of course a flyback is a type of switching power supply (having designed a couple). And sweep tubes were commonly used in lower cost amateur SW transmitters, probably running pretty close to Class C (I think you could get 100W PEP SSB out of a 6JE6). You tuned the final to minimum current.
By the way this is what the horizontal linearity or efficiency coil is for; to tune
the HOT circuit for minimum current which, at least in my B&W sets is also the best linearity. I imagine it's the same in color sets too?
Cliff
Old 03-07-2011, 12:26 PM
RCA was the last major mfr. to use intercarrier audio. I guess Sarnoff didn't want to lower himself to paying royalties to Motorola Inc.
