Old 06-21-2011, 05:44 PM
Pete Deksnis's Avatar
15GP22 demo @ ETF 2007
So earlier on they were using different basing if I understand this right, which would place my tube later on in the development timeline and peg tubes with different pin counts as earlier ones?
Something like that. I liken these exercises to riding an old mountain railroad for the first time: plenty of hidden curves ahead; somebody was there before us to build the thing, but it's all new now...
Pete
Old 06-21-2011, 07:38 PM
John Folsom's Avatar
Nick, The earlier tubes had a 14 pin stem and base. I would speculate that this was because they had a 14 pin stem and base in the inventory. Later on, it became obvious that additional electrical isolation was needed between the convergence pin at [edit] 7-9KV and the other pins, so a 20 pin stem and base were developed, allowing 3 blank pin locations on either side of the convergence electorde.
I just checked my Sparton metal bell CRT, and it is a 20 pin 6 bolt CRT just like yours, with a type number of C73547, just like yours. My bell rim number is D255, and I believe Pete said you rim number is D205 (?). This all seems to make sense. My Sparton set is a early 1953 NTSC set, as best I can tell.
John Folsom
Old 06-21-2011, 08:14 PM
miniman82's Avatar
First Light: 1952-2011
Update: took the tube out of the box, and it's definitely D225. Only 30 made between ours, if the assumtion of a production serial code is correct.
Evolution...
Old 06-21-2011, 08:25 PM
Thanks, Nick. Well it is all very interesting.
John Folsom
Old 06-21-2011, 09:00 PM
miniman82's Avatar
Originally Posted by John Folsom View Post
Later on, it became obvious that additional electrical isolation was needed between the convergence pin at 3-4KV and the other pins, so a 20 pin stem and base were developed, allowing 3 blank pin locations on either side of the convergence electorde.
Makes perfect sense.
Hey, speaking of convergence...
This thing has a long string of megohm resistors coming off the HV rectifier, with the convergence pot right in the middle and more resistors after it. It looks electrically just like the way it was done on the CT-100, except by that time they actually had a 50meg resistor to use in the circuit. What do your proto sets have for convergence?
Evolution...
Old 06-21-2011, 09:48 PM
Steve McVoy's Avatar
Your set doesn't appear to have a convergence transformer like the CT-100, so the question becomes how did they accomplish dynamic convergence, or maybe the question is "did they use dynamic convergence". I would be curious to know if there are other connections (capacitors to be specific) to the convergence grid of the CRT?
Old 06-21-2011, 10:32 PM
Nick, Here is a photo of the bottom side of he CBS prototype. It appears to use large high-voltage resistors, but it has been many years since I was under the chassis, so the details are vague. I have never had the HV cage cover off the Sparton, but as it appears to be a close cousin to the production Sparton set shown in Sames, I expect it will also have 50 megohm (or similar) high voltage resistors. Both of these sets are, shall we say, more mature than your set. :-)
John Folsom
Old 06-21-2011, 10:48 PM
Penthode's Avatar
Penthode Penthode is offline
If this prototype dates from 1950-51, how far along was it's development?
Has anyone identified whether this is a set still running on the dot sequential principle or whether the design had progressed to the constant luminance principle with interleaved chroma?
Is there any schematic information with this set? It would be very interesting to reverse engineer this set to find out what the design comprises of.
Note: seems I missed an earlier part of this thread. I see from Ed's post that progress had moved to CPA and possibly later to the early '53 NTSC development closer to the final standard.
It will be interesting to see what the reverse engineering reveals.
Old 06-22-2011, 09:57 AM
miniman82's Avatar
That's exactly what I'm wondering. The other end of the resistor string has a wire that goes under the chassis, with connections to many different parts. So perhaps it does have dynamic, but it's done in a different way?
Thanks for the picture, John. I can see the 50meg resistors on that set, so you're right- it is more 'advanced' than mine.
Evolution...
Old 06-22-2011, 11:00 AM
Nick, Attached is a scan of the schematic from the June 1951 RCA symposium on tricolor picture tube development. While this features a RF HV supply and differs considerably from your sets configuration, it does show both vertical and horizontal dynamic convergence transformers. It would seem quite odd if your set did not incorporate some type of dynamic convergence.
John Folsom
Old 06-22-2011, 11:53 AM
Nick, if you follow the wiper of the convergence pot, where does it go? This is where the convergence stuff would be.
Old 06-22-2011, 02:26 PM
miniman82's Avatar
To the CRT, nowhere else.
Evolution...
Old 06-22-2011, 02:29 PM
I think that means that the set has no dynamic convergence, which is strange. But a full schematic will tell for sure.
If you look at the schematic that John posted you'll see a 10kv capacitor from the convergence pot to the circuitry that provides the waveforms for convergence.
Old 06-22-2011, 02:35 PM
miniman82's Avatar
There is a doorknob cap mounted under the chassis, but I have no idea what it's connected to.
Evolution...
Old 06-22-2011, 06:04 PM
Dave A's Avatar
Dave A Dave A is offline
For John's request and for comparison, my 6-bolt, 14 pin prototype tube is paper tagged;
Developmental type - C73293C
Serial - L3046R
Rim stamped - D229
And it has acquired a swooping crack right across the faceplate but not edge to edge. No idea how that happened. Have not looked at it in 5 years. Gotta be careful now.
