Old 10-13-2013, 10:59 PM
TinCanAlley's Avatar
Okay, spent the better part of today looking into why the setup doesn't produce a line. This is what I found out, but not why or how to fix.....
The G1 voltage controls brightness and the higher the voltage, the dimmer the output. The voltage should be around 142V for normal and actually measures out around 147 - 150V. That's not too bad. It's when the setup mode is entered that things change. The voltage of the G1s goes up to 190V and that must be why I can't see the lines when adjusting the G2. 190V is making it too dim to see.
Now why the voltage goes up that high is beyond me. I looked over the schematics and see an 18K and a 1.8K resistor on the setup side of the switch and am not sure if one of those (or a combination of both) could account for the voltage difference.
Old 11-06-2013, 11:23 PM
boora2 boora2 is offline
Banned
Ringing,assuming the damping resistor across the line linearity coil is ok,is often caused by the bypass cap in the video output stages being o/c,value usually 10-33uf 250v,make sure,as with everything you don't use chinese sxxt as replacements
