Old 02-22-2020, 07:00 PM
Pretty sure they were originally sealed in wax in an attempt to keep out moisture. Possibly vacuum impregnated too. Although I'll have to admit I wasn't around early enough to remember seeing those in NOS form.
but i don't think wax was meant to be dropping off them , so much that you can not read the numbers on them
Old 02-22-2020, 07:37 PM
Kevin Kuehn's Avatar
Workin' Late Again
Try a heat gun and quickly wipe the excess wax off. They often look as new underneath that old dirty wax.
Old 02-23-2020, 08:08 PM
If the wax is soft you can scrape it with a fingernail. If you have a lousy soldering iron you can swipe it over the coating to melt and clarify it....I tend to use cheap garage sale irons that fail every 1-4 years so I don't mind doing things like that to them.
If you ever find a set that was used a long time with a badly leaking cap the cap will have bubbles all over it, and the ends will be melted out....
Old 02-25-2020, 10:47 PM
sloooly making progress...
https://imgur.com/NSJHxx0
Old 02-26-2020, 12:18 AM
Workin' Late Again
Looking good.
Old 02-26-2020, 09:09 AM
Nice work.
The 630, early Dumonts, 50s color sets, and Philco sets before the late 50s are among the most laborious sets to recap.
Old 02-26-2020, 02:10 PM
oddly enough, the 418P25496MB3 cap (.25uf 600v) is damn HUGE compared to all the other new ones.
Old 03-02-2020, 09:34 PM
Funny how the schematics in both the RCA630TS service manual and the Riders for the Fada 895,are MUCH easier to follow than the SAMs are of the time
Old 03-03-2020, 08:18 PM
i just had a major WTF moment when putting in the 2nd .25 cap.
https://imgur.com/XVO6xyK
I noticed that there was a resistor going to nowhere, as is it was never hooked up.
it has one end where it should, but one just hanging.
checking all the schematics, it seems that this is NOT right :O
https://imgur.com/cVDDVHb
SAMS
https://imgur.com/lJV5DsN
FADA
Is this a mistake from the original maker?
fix or leave as is?
Confusing...
Old 03-03-2020, 09:02 PM
I don't know, but I suspect if you try it, it will work, but the picture control setting will have to be a little different. If it does work, I would connect it permanently.
Old 03-03-2020, 11:35 PM
Workin' Late Again
The contrast circuit is a manual rf/if gain control.
Old 03-04-2020, 12:00 AM
Workin' Late Again
I'd leave that resistor as original(unconnected) for the time being, at least until you have the set operational. The 680k resistor's loose end is shown being tied to the 275v B+ in the Riders schematic, but that line is also being fed a bias voltage from the picture(contrast control) circuit. One has to assume it originally worked "as is". At some later point you can always try connecting it to B+, just to see how it affects the picture and sound.
Old 03-04-2020, 09:47 AM
There in lies the catch...
I don't know if the tuner and IF will ever work on this, due to the extreme age & damaged IF coil which I fixed as best I could, even if the coil works, the tuning for it is lost due to it being taken apart and fixed, and the tuning slug broken/glued.
So, options are...
put coil in and try to eyeball it while leaving all the other coils untouched hoping they are still in tune and can get lucky with getting the broken one tuned.
Find an old generation sweep marker generator someplace with the right ranges for this set that they DON'T WANT a king's random for and attempt my first alignment.
Or, skip the tuner/IF completely and do direct A/V input.
Old 03-04-2020, 10:52 AM
dtvmcdonald's Avatar
So, options are...
The chance of getting a watchable picture from such a single repaired
coil, just playing with it and only it, are very high. Just play.
Old 03-04-2020, 10:31 PM
Workin' Late Again
Just for fun I looked up the RCA part number for the 630's 1st video IF coil and crossed it to a Meissner 17-1001. One of which is listed on ebay. Electrical specs look like a match. I'm not sure about the mounting, but there's a good chance it'll fit? Maybe you can message the seller and he'd be kind enough to measure the mounting bolt spacing. I agree your old one may work, but having this as a backup may let you sleep better at night.
https://www.ebay.com/itm/Meissner-17...5/291470458045
https://i.ebayimg.com/images/g/3e8AA...a3/s-l1600.jpg
https://live.staticflickr.com/65535/...a1bcddbf_b.jpg
