Old 02-15-2022, 08:51 PM
While experimenting with shielding the filament transformer and tuner tubes, the problem went away! No more vertical distortion and only minor horizontal.
I figure something, somewhere wasn't making good contact.
It's not perfect, but I'll take it.
This pretty well sums it up.
Old 02-15-2022, 08:57 PM
Kevin Kuehn's Avatar
Workin' Late Again
Aw man. Now we're not going to know what fixed it.
Old 02-15-2022, 10:32 PM
Yeah, and there's no reason to think it won't come back. Could be a chassis rivet not making good contact, a cold solder joint, intermittent tube short...
Old 02-15-2022, 11:08 PM
Time for some wiggling and tapping of things.
Old 02-16-2022, 01:21 AM
Tom9589 Tom9589 is offline
Bob, how is the audio hum now?
Old 02-16-2022, 01:22 AM
I eliminated it by redesigning the 1st audio amp.
Old 02-16-2022, 05:53 AM
edison64's Avatar
edison64 edison64 is offline
THE A-1 WIRELESS MAN
Location: NW INDIANA THE MAPLE CITY LA PORTE (GO SLICERS)
It looks pretty good, considering it probably never played that good when it came from the factory. LOL.
RCA VICTOR and its dealers bring you......
Old 02-16-2022, 08:03 AM
Dang Dude! Seldom see linearity that good on electromagnetic-deflection sets.
Old 02-16-2022, 10:16 AM
Not so fast Distortion problem is back and a new issue has cropped up. I used to get good focus in the middle of the control but now I need to have it full clockwise.
The HV box is power in a rather odd way that makes me think the two problems are related.
Old 02-16-2022, 11:19 AM
You sure that's not Rosemary's Television you have there?!
Old 02-16-2022, 01:53 PM
Just making wild guesses, not having really had the chance to ever work on one of these yet...
The HV circuit is clearly a free running tuned RC circuit run from main bias with a tie to the AC line, assuming the 2 HV caps were replaced, (500pf?)
And guessing that other caps / resistors in the area were also changed with newer kinds, and this all could perhaps change the resonant frequency of the HV circuit, or overall behavior which could possibly include the proximity of the CRT to the chassis, and the parts in it.
IE, starting some kind of weird feedback loop that just won't break.
But, as stated, this is just a guess!
Old 02-16-2022, 03:17 PM
I still say try the lantern battery for the tuner filaments. Somewhere I saw a series filament TV that had rectifiers for the tuner filaments. Wish I could find it easily....
Old 02-16-2022, 05:37 PM
Heading out to the hardware store now. I'll be posting a video soon where I experiment.
I just discovered that pushing on one of the filter cap bases has a minor effect on the distortion.
If I lift the CRT up off the chassis, the vertical distortion diminishes and disappear altogether at about 12 inches. The horizontal distortion is always present.
The two 500pF caps are ceramic doorknobs and I did not replace them. I did replace the 12SN7 inside the box and retuned the trimmer cap. Seems to be working OK now.
Old 02-16-2022, 07:08 PM
What I find most confusing is that installing a shield from an Admiral 19A1 did absolutely nothing. However, moving the CRT away from the chassis eliminates the vertical 60Hz interference.
Old 02-16-2022, 08:06 PM
If the shield is Aluminum rather than mu metal, it won’t be effective in reducing interference from magnetic fields.
