Old 05-15-2021, 01:47 PM
https://i.imgur.com/qFxnIqI.jpg
ready to install yoke/ pincushion assembly
Houston, we have a problem!
https://i.imgur.com/3IvjiCQ.jpg
the bell of this CRT is longer than the other, and it does not fit
We have a work around!!
https://i.imgur.com/SCIHUoK.jpg
motherboard standoffs
https://i.imgur.com/NBLz7Zf.jpg
all installed
Old 05-16-2021, 10:53 AM
a close look at the weird blue light
https://i.imgur.com/oXmNpN4.jpg
Old 05-16-2021, 09:25 PM
seems i had a dead 5U4GB and never knew it.
only 1 of 2 was working.
Old 05-17-2021, 08:15 AM
So, this weekend's work proved that the 21fp4c does indeed work, with the added benefit of a cool radioactive blue glow at the join line where it was rebuilt, only complication was attaching the mounting bracket for the yoke/ pincushion assembly, I have yet to work out how to deal with lack of centering, as it was originally done with the focus PM, I will have to see what I have in my junk pile from projection tubes.
As for the bad 5u4gb, must have been bad from the start, new one will take a while to get here, is it safe to keep running on 1? grab one from another set?
There is still a bunch of minor suff to do, but it all seems to be working, and I don't think I will be able to get rid of ALL the audio buzz as long as I am using a cable box as source.
Old 05-17-2021, 09:50 AM
old_coot88 old_coot88 is online now
Sharply-defined blue glowing spots are from stray electron bombardment and not a problem, as opposed to diffuse glow throughout the gun area (indicating gas).
Old 05-17-2021, 10:20 AM
I really did not think it was much of a problem, since it seemed to be working OK, I just find it weirdly fascinating as to why it's only glowing near the new section of neck, right at the weld point, and am rather curious about it, if anything else!
Old 05-18-2021, 06:03 AM
Just cant get clear sound on the set (buzz) , I was able to get a good picture by boosting gain, but the sound is not clear, not sure if this is because the sound IF coils are still old and have problems, 2 of the video ones were replaced for some reason, or video IF is still wacky, ( intercarrier set ), but the sound just won't clean up completely, good video, however.
So gonna try tuner fed-video and direct audio. :O
Old 05-23-2021, 02:11 PM
https://www.youtube.com/watch?v=5JIbvXzbRUI
latest test
most likely the final configuration
tuner is still bad, chan 3-4 is unstable but 7 seems ok
this is with my home transmitter and audio fed in
Old 05-23-2021, 03:07 PM
Nice!
Old 05-25-2021, 11:27 PM
https://i.imgur.com/IfiWlBX.jpg
all together and in it's final place.
Old 06-02-2021, 10:50 PM
Now that the Arvin is done, I need another TV to restore to feed my addiction, but that is not so easy down here
Old 06-03-2021, 12:40 AM
The ETF meet is Saturday..... You can find pretty much anything you could want there.
Old 06-03-2021, 05:24 AM
but getting anything from there to here is the problem....
Old 06-03-2021, 01:56 PM
dtvmcdonald's Avatar
Really?
I want a 21CT55 with a really good great vacuum 21AXP22 or an installed
glass tube retrofit kit.
I'll be there.
Old 06-03-2021, 04:06 PM
Really?
I'll be there.
Yeah.. rub some salt in the wounds , why don't ya!
