Old 05-30-2026, 08:19 AM
vol.2's Avatar
vol.2 vol.2 is offline
jailbars are hard
Old 05-30-2026, 04:11 PM
TinCanAlley's Avatar
jailbars are hard
I finally made some progress.....
I've been calibrating using the Video Essentials DVD and their pluge patterns and their instructions. This has always led to the image being dark on any other DVDs I've used, so I always adjust it. That has always led to jailbars. I decided to search for ways to adjust that differ from theirs. I think I've solved it and with decent results.
I started with contrast mid point. I then brough up brightness until the blacks were crushed and darker areas started turning grey. I then backed it off until blacks were black again. I then brought up the contrast to get a bright enough image. I'm positive this level of contrast is considered in the blooming range, but it has to be. Now all the programs I've tested show no jailbars at all. The image is very watchable, but I would like a little more light in the light areas, but to do so means bringing up the brightness and that crushes the blacks and brings up jailbars. I know it's been a while since I've adjusted and watched an old CRT television, so maybe I'm asking too much for the technology of 1974.
For testing I took my 13" Hitachi from 1981 and adjusted it the way I was the Zenith and I got faint jailbars. Readjusting the new way took them away and gave another very watchable, but not perfect, image.
So either this is a limitation of the technology, or I have an issue in the brightness/contrast circuit. Eitherway, I'm going to leave it be and enjoy it.
I'm now working on removing all the components of my 9-57 horizontal board so I can piggyback the 9-90 horizontal and be able to use a VCR without the waving at the top. I'm also hoping that the board will better center the image horizontally than the current module. It's about 1" or so more to the right than the last one that failed. Not only that, but I hope it solves another horizontal issue I'm having using the original 9-57 module. When the set it started cold, the image is messed up horizontally, but not like before when it was rolling out of sycn. It's a stationary issue and only goes away when I change channels and back, or sometimes on its own after a minute or so.
I wish I had to room for storing more stuff as there's someone near me giving away a 25EC58 chassis and same CRT as mine. Would be nice to have a spare I could use to compare or salvage for parts.
Old 06-04-2026, 03:26 PM
Well jailbars are gone and all out of spec parts replaced. Set is fully operational and working like a charm. Next is the touch up of paint and painting of stand.
Thanks for everyone's help. This thread is done.
Old 06-04-2026, 07:05 PM
vol.2's Avatar
That's awesome. Would like to see some good photos of the finished set though!
Would be cool to see the case and also a decent close up of the video.
Old 06-05-2026, 12:09 AM
ronl ronl is offline
Source of free vintage Canadian tv service info.Caretaker of various 1920 to 70s radios,a Farnsworth 651p tv,a RCA Ctc5 and a few 50s tvs.
Old 06-05-2026, 08:45 AM
Which part was causing the jailbars?
This thread started getting too verbose and shotgunny and I tuned out a few pages in.
Old 06-07-2026, 05:22 PM
The service manual has it as video amp 4, but it's actually 3 and the set doesn't have a 4. Anyway, I replaced the 24V Zener and the .001 1KV decoupling cap on that's amp's transistor. While many said the ringing I see when I scope the ABL, and along that path, wasn't the source of the bars, it quite possibly was. I tried cleaning up the ringing from the source, but I didn't know enough to do that. The ABL's collector is sourced from the tripler. The 500ohm resistor goes to a 7.5V zener and spark gap. The Zener is on the wiper of the ABL pot which feeds the ABL transistor. I noticed that if I turned the pot, the bars changed intensity. Not much, but noticeable. I then set the ABL per SM and started tracing the circuit better. I found that the brightness, contrast, ABL, Blanker, etc. all came together and funneled into the video amp. Looking closer I noticed the zener on the transistor base and the decoupling capacitor. Didn't bother doing one than the other to see, just did both as I had them.
Anyway, while the bars are gone for standard viewing, I can still make them appear faintly if I crank the brighness and contrast beyond what is normal levels, but at the normal levels for viewing, even dark scenes, they're gone.
Old 06-07-2026, 05:27 PM
I still have to do some research on the cabinet paint. I am told it is lacquer and I don't think I've ever done anything with that kind of paint. I've see other's paint theirs completely, base and all, but they go with a bright white. From what I understand, the paint color used was and off white (imperial something). If I can't figure out how to touch it up and it not looking like I did, I'll repaint the entire cabinet in the original color, just won't be able to get it in lacquer.
A couple here helped me get my camera setting for taking pictures of the screen, but I don't know how to get video from my phone that is in synch with the screen. Also, I am not sure why every picture I take seems to magnify the phosphor dot patter.
Old 06-08-2026, 11:57 AM
Has to be a way to take a picture that accurately captures the image on screen. I took 40+ pics and these 2 were the best. I have a lower resolution Nikon SLR digital camera. I wonder if that one can be set properly for better images...???
Old 06-08-2026, 09:20 PM
vol.2's Avatar
Looks pretty good! The colors are definitely coming through, and I don't see any visual artifacts.
Yeah, taking pictures of a CRT can be tricky. I also will typically just take a bunch and pick the best.
I have found that the orientation of the CCD makes a huge difference though. Sometimes, if the picture is flashing too much, turning the camera 90 degrees will cure it. Sometimes it also requires that I move my camera closer or further away from the screen. Typically, I can get an acceptable picture by cycling through those two parameters (rotate camera, slowly move camera towards and away from CRT).
Old 06-10-2026, 03:37 PM
I took so many pictures and ended up with 4 that I really liked, but still below in person visual quality. It's a bit annoying that in person I see scan lines, but not dot pattern in that line. In pics, it becomes quite noticeable with the higher resolutions. I think I'm going to wait til it's dark outside, setup a tripod, turn off all lights and try it that way. I'm sure the light behind the set is going to be picked up by the camera and it will adjust for that and might be part of my issue.
Old 06-10-2026, 03:55 PM
Thought I'd add something regarding the perforated cover over the swing door. I've noticed in a few pics I've seen on the internet that, like mine, many had dents in it. I had quite a few and some were pretty bad. Don't know what happened to it, but it had a rough life.
The cover is aluminum is held to the door by tabs that are left when the piece is cut to fit the door. Those tabs are bent over to hold it in place. If you carefully bend those tabs back, the mesh piece will come off. I took that piece, found the smoothest and flattest surface on which I placed the thickest piece of paper I could find to place between the surface and cover so as not to scratch it. With the cover face down, I gently tapped the dented areas with a flathead hammer until it was smooth as possible. Flipping it over often to see the progress. When it was done I put it back and bent the tabs over. I wouldn't recommend taking it off too often as the tabs will break.
The results are great. It's only under close inspection you can see it isn't perfect.
The after pic isn't the best angle, but I am too lazy to take a proper pic. Also, looking at the pic, I need to remove the transducer and clean the screen and opening.
Old 06-10-2026, 03:59 PM
vol.2's Avatar
Doing it in the dark is the typical way people photograph CRTs, but beware that it exacerbates refresh rate issues. You will probably have to mess around with the distance and orientation a lot to get the right shot, and even then, choosing the best one between blanking periods to get one without the black bars in it
Old 06-10-2026, 04:15 PM
I found a company that can put the Bermuda Shell (is a Behr paint color) that's used on the Avante in a spray can. I have choices to make. The current paint is lacquer, so that's a no go. This paint is enamel and I have a choice of flat, satin, semi or full gloss. I know this set isn't as shiny as it once was, but I'm assuming satin or semi is a close match for sheen.
I've only seen this set new when I was a kid, so I can't remember detail about the paint other than it was white.
Old 06-10-2026, 09:25 PM
vol.2's Avatar
From my memory, the paint sheen was not too dissimilar from plastic and was what I would estimate as stain or semigloss.
Behr should be at home depot. I think you can probably go to one and get paint squares to see what the finish would be like.
I guess if I had to err on the side of caution, I'd go with the duller finish, as I don't think they were super shiny. But go with what you like.
