Old 08-28-2007, 08:57 PM
I've been blessed!
I just acquired a CTC-5
Pete Deksnis contacted me to say there was one available that "might be close enough" to me.
Well, it was about 200 miles away in Fort Wayne ...hmmm..
And a coworker hails from Indiana, and has relatives there ... hmmm
And his brother goes between northwest Indiana and Fort Wayne from time to time ... hmmm
And by the way, the owner, John Leone (not sure if he hangs out here) was GIVING IT AWAY if someone would only promise to restore it and let him see the result -
It arrived yesterday, and I've only had time to remove the back and stare fondly at the chassis.
The attached pictures are from before it was picked up in Fort Wayne.
It's a Westcott Color Super Model 21CT785-5U, the last 5 meaning Mahogany and the U indicating UHF tuner included. There is a tag on the tube cap indicating the CRT was replaced on February 23 1962, but it also has the date code recorded as 6217, which would be in April. I can't see where to read the actual date code on the CRT. It reportedly worked when last turned on over 10 years ago. A quick inspection shows no obvious signs of problems, flyback looks good.
As you can see, it also looks intact with knobs and all.
First order of business will be a recap - if anyone has already created a list of required caps, I'd appreciate it, otherwise that's the first step for me.
I'll post some more "before" pix as soon as I can.
Thanks again to Pete and John, and Jim Laud, the transporter.
