Old 06-26-2011, 08:23 AM
Originally Posted by VintagePC View Post
That could well do it!
Considering C61 is part of what comes out of the 1x2 cap -> through a transformer.
That means without C61, your flyback won't operate properly.
I'd connect it in the same way as C62 - using the optional 255V connection.
If C61 was indeed missing, it'll be interesting to see what happens when he replaces it, since it is the bypass/'filter' for the bootstrapped (B boost) voltage. Since the vertical oscillator is supplied from B boost, the absence of C61 was probably introducing some wonkiness into the vertical waveform too.
What still puzzles me is- he was drawing a healthy 'air arc' off the plate connector of the 1X2. Assuming the replacement 1X2 is good, there should definitely be adequate HV coming out of it.. assuming there is no short to ground. One remaining possibility is that the second 1X2 is gassy. So one question- is the 1X2 getting hot after a few minutes of running? If it's hot, like too hot to touch, it would indicate the tube's gassy (even though it might still test good on a tester).
Old 06-26-2011, 12:10 PM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
I've only had the set on for seconds after noticing the problem so I don't know if the 1X2 is hot to the touch. I could test this theory if you think it's ok to leave the set powered up for that long.
Old 06-26-2011, 12:18 PM
VintagePC's Avatar
Tube bug got me 05/2010
It should be all right, (and I'm sure you know this) but don't run it unattended. (and replace C61 before you do fire it up!)
I like to run things through a power bar so I have a kill switch on hand that's not near/on the set, just in case. Then, keep watching and listening for any funny business and kill it if anything else starts acting weird. Keep a good eye on the flyback and kill the power if it starts to drip wax!
I should add that gassy tubes usually have a blue-violet flickering glow to them, which is in the _space_ inside the tube... What it looks like you have (and you can confirm this, since cameras don't usually do fluorescent colours justice) is a pure, deep blue coming from the inner layer of glass itself- that's entirely the fluorescent emission of the glass from being bombarded with high-energy electrons.
There's a couple of videos on YouTube (heh) if you search "gassy tubes" that will help you distinguish between the two.
Old 06-26-2011, 12:49 PM
Umm.. considering the rarity and irreplacibility of that flyback, and since you haven't already run it for more than a few seconds in the fault state, please hold off on this test.
Rather (after replacing C61), do the 'air arc' test again. It will confirm whether the fly's putting out without loading it down.
Now, if the fly's putting out, install the 1X2 with the plate cap connected, and remove the doorknob. This will avoid loading the flyback (in case the tube is gassy). If the tube is good, the HV should come up and light the CRT. If the 1X2 is gassy, it may fry the 470K resistor (R89) in series with the HV lead. R89 is thus "sacrificial" and takes the load otherwise borne by the flyback with a gassy 1X2. Much easier to replace a resistor than the flyback.
Old 06-26-2011, 12:57 PM
Yah, some tubes can glow pure blue and work fine. I have observed this in a couple of sets.
Purple, not so good. The photo shows a 5U4G rectifier in my RCA T-100 just before it failed completely. Definitely purple rather than blue. There was nothing wrong with the TV, that old tube just gave up the ghost.
Old 06-26-2011, 01:31 PM
vts1134's Avatar
Looking For Time
I guess .1% wins this time. I found C61. It is a .05 instead of a .035 though. It was one of the black beauties and didn't have it's rating on it. It had the same marking bands as two other black beauties that were .05 though.
A few youtube searches on gassy tubes and I think this is what I have. The last two posts came in after I did the test so didn't have a chance to read the "don't do that" warning. The set was still only on for less than a minute.
http://www.flickr.com/photos/23097242@N03/5873904324/
This will help make it a little easier to see what the tube is doing. The video is of the new tube. The old tube does close to the same thing, just not nearly as much blue glow. I suppose #3 could be the charm.
Old 06-26-2011, 01:47 PM
Are you still hearing the hissing or spitting sound? A length of plastic tube held to your ear can help you pinpoint its location.
Old 06-26-2011, 01:55 PM
vts1134's Avatar
Looking For Time
I am hearing a sparking noise, but I think it's coming from the 1X2 itself. You can see in the video that it is sparking on the inside. This is also what the old tube did.
Killer suggestion on the length of tube though. I will definitely remember that for the future.
Old 06-26-2011, 01:58 PM
miniman82's Avatar
First Light: 1952-2011
If the doorknob isn't causing the arcing, it could be the socket itself. Have you checked it yet? Carbon tracking on HV parts can cause shorts from seemingly nowhere, so make sure you inspect the rectifier tube socket and replace it if you're in any doubt.
Evolution...
Old 06-26-2011, 02:01 PM
vts1134's Avatar
Looking For Time
Interesting thought. I'll inspect.
Old 06-26-2011, 02:06 PM
miniman82's Avatar
Damn, that thing is TOASTY!
http://www.youtube.com/watch?v=x7KK7bXJV2c
Evolution...
Old 06-26-2011, 02:29 PM
vts1134's Avatar
Looking For Time
Originally Posted by roundscreen View Post
Another check may be to see if the crt is your problem. Put the anode connector in a plastic or glass cup, Fire up the set and see if the problem goes away.
Ed
Tried this and it's not the problem.
Old 06-26-2011, 03:28 PM
vts1134's Avatar
Looking For Time
Ok tests ran, here are the results. Fly is air arcing away. Door knob removed and HV going right to the picture tube. I want to rewind a bit to before. Miniman82 first suggested removing the doorknob cap and firing the set up to see if that solved the problem. The doorknob cap is secured to the base of the rectifier through a screw in the base to the top of the cap. On my first test I removed the screw. On this test I removed the screw and MADE SURE that the base was not in contact with the cap at all. Different result. The tube did not glow or crackle at all this time. Unfortunately a new arc has developed. It is between the flyback and the filament winding for the rectifier. I've indicated where it is with the white arrows below. It is not constant, and only happened 8 or so times total with all the tests I have done tonight. It seems that Miniman82 might have put his money in the right place and the doorknob is toast. It is not shorted to ground but it could be toast. A new doorknob might be the answer. I don't know what to do about the sparking flyback though.
Old 06-26-2011, 03:42 PM
VintagePC's Avatar
Most people here will coat the flyback with a "sensor-safe" silicone product (regular silicone produces ammonia or acetic acid as it cures, which corrodes copper). That will likely kill the arcing. A few wraps of PVC electrical tape might work in a pinch for testing until you can get the right stuff.
Old 06-26-2011, 03:50 PM
miniman82's Avatar
At this point, I'd recomment replacing the filament winding for the rectifier and the doorknob cap. I often find filament windings have degraded insulation, and that's never a good thing around HV.
Evolution...
