Old 08-07-2023, 04:55 PM
Hi Guys..... You guys are going the wrong way..... You know the voltage on Pin 9 of V21
is measured correctly is way off.... That grid is biased so high as to capture the burst
signal, and it's way off..... If you guys did the AFC alignment as in the sams, and you
finish with rainbow bars, then it's time to stop. And if you got the peak deflection
(which as Timmy says is the highest voltage, then you are done there for now).
V21 - Pin 3 Voltage is low - Why? Check C118, disconnect one side & see if voltage
goes up, you don't have to replace it.
Check everything that leads to Pin 9 of V21, Backtrack through stuff that goes to
that pin..... Something going on there.....
I believe at this point you guys have a running Color Osc. and as long as you have the
cool rainbow stuff on the screen it's working, time to go someplace else.... I think
the burst signal is being blocked from reaching the Osc. & properly syncing it.
So you have to go back. A while ago Timmy said the top & bottom of the
screen was black, or dark, That's also a clue - not the color osc.
What are the voltages on V4 Pin 3, 2 & 1?
What are the voltages V19 Pin 1, 9, & 8?
Whenever you have problems, Always make your first step voltage checks.....
Old 08-07-2023, 05:06 PM
ok I’ll look into this and hopefully I can find something and end this crazy madness
Old 08-07-2023, 05:21 PM
On V19 the difference in voltages on pins 6 & 3 is really pretty big considering there
is a low ohm coil between those two pins...... Timmy are your readings correct?
Is that Primary winding of L29 Pins 1 & 3 ok? I don't think there should be
such a large difference in Voltage unless possibly that primary is open...
Just test it don't replace it, be sure solder connections look good
no corrosion, cold joints..... Is it around 9 ohms...?
Old 08-07-2023, 05:36 PM
The voltages for v19 I had posted under the other voltages they were 1 95.6 9 -40.7 8 5.86 I had noticed v4 got extremely hot very quickly while the others were still somewhat cool.
Old 08-07-2023, 06:21 PM
nul
Old 08-07-2023, 06:39 PM
I don't think this is a worry - The Video Amplifier half of V4 has a bit of
power running through it, I don't think it's a problem....
See the size of the plate resistor - and it's 4W.....
Old 08-07-2023, 06:49 PM
Pin 9 of v21 was -44v
Old 08-07-2023, 07:26 PM
have you got another V21 to try?
whats the voltage on pin 9 V19? -40.7? also too low
Old 08-07-2023, 07:38 PM
All the voltages are on the previous page and unfortunately I don’t have another 6gh8 or even a sub with a different number Something is definitely going on here with this set I didn’t loose the color from doing anything it just crapped out
Old 08-07-2023, 07:47 PM
All of this points to one thing, is related TO one place, the pulse winding on the flyback, pins 13-14, this goes to the Burst gate, horz blanking, color killer, and others, first two you listed having very low than normal voltage readings, will be tricky to find the cause
Old 08-07-2023, 07:49 PM
I suspect you will find that the -10 on pin V4 is also low.
Old 08-07-2023, 07:54 PM
Actually... -40V is too high, higher than -75V as -40V is closer to 0V
than -75V...
With these bias voltages & if you look at the signal from the scope trace
the tube is conducting just on the very tips of the signal - sending that part
of the signal on to do just that item's job.
Old 08-07-2023, 07:58 PM
I was thinking about that too, & wondering how the HV & Boost Voltages are,
but not willing to ask because I think Timmy has enough to do right now....
I'm still having visions of this tv on fire out back in the grass field.....
Old 08-07-2023, 08:04 PM
I'm also hoping that the color killer knob is set so that it lets the color run even
if it's a B&W show, or makes color snow when there is nothing connected to
the tuner. Even if in this state, it will not produce color snow, when we
figure out what it is, I want to know that the color will come on, and
it's not blocked again by the color killer....
But then again, you guys have the Osc. running ok, so maybe
forget this comment for now.....
Old 08-08-2023, 07:30 AM
Ok so color killer is up for color boost voltages are 640v measures 634v 770v measures 800v and the voltage coming from the flyback 13-14 at c134 814v I’ll post the other voltages from v21 and v4
Ok v4 3 1.71v and flashing 2 .580v 1 26v
V19 1 95v 9 -40v 8 5.88v
L29 primary 9.1 ohms
