Old 04-27-2023, 11:08 AM
equivalent part on the SAMS very clear, 680pf.
Thanks the schematic is blurry that I have.
Old 04-27-2023, 01:02 PM
Chris K Chris K is offline
Anyone have the schematic for the ts-4h to confirm c158 it’s very blurry looks like a 680
I agree...680pF on both sources...Sams and the one from the TS-4H schematic in the service manual
Old 04-27-2023, 11:55 AM
hmmm, SAMS has that cap and the 900pf near it listed as "fixed trimmer capacitor" whatever that is..
Old 04-27-2023, 12:07 PM
It’s a mica
Old 04-27-2023, 12:54 PM
where you can get an exact replacement for the 680 if needed,
https://www.mouser.com/ProductDetail...dopvQ9sA%3D%3D
the same is not for the 900pf
https://www.mouser.com/ProductDetail...KcNnbMvA%3D%3D
best you can get is 910 :/
Old 04-27-2023, 01:04 PM
Tim, remember keep track of the time spent on this and the price of the parts. I'll compensate you for everything you have done.
Old 04-27-2023, 01:06 PM
I replaced the 680 900 and 100 with micas in my sets things are much more stable
Old 04-27-2023, 02:05 PM
Does anyone have the other parts of the ts4-h schematic to see exactly what voltage b+ And b++ is supposed to be.
Old 04-27-2023, 02:15 PM
Bob stated that in a working set, B++ be around 230 volts, given the ballast and respective loads are correct.
Old 04-27-2023, 02:29 PM
But the b+ is very low and I disconnected b+ and it still has 111v on the wire and in taking that off the tearing of the picture remains the same so maybe the clipper is not running because of the low voltage to that tube. I don’t know at this point how to get that voltage up it’s 39v short if it’s 150v and my ballast with resistors made no difference at all I checked the cap responsible for the b+ it’s good. So if there’s something dragging the voltage down I would say it may be on the b++ that’s at around 276v if 230v is good then the 40v should go to the low b+. Getting lost a bit.
Old 04-27-2023, 02:35 PM
I'm restoring a TS-4J right now and B+ is only 90 volts but the set works fine.
B+ is derived from 6 tubes acting as a voltage divider.
Old 04-27-2023, 02:40 PM
Well I went over ever tube so whatever the reason is for the picture tearing from side to side maybe the problem this is where it’s starting to stump be from a simple TV set. There is a perfect picture that can be seen between the tearing.
Old 04-27-2023, 02:46 PM
Ahh OK, I see!
Every tube that has it's cathode tied to B+ is working in tandem to charge up the bias cap and circuit for the B+ area. Sneaky!
EDIT-
I figured out how they did that trick in my Stromberg Carlson TV, where they sourced the secondary 90v from 2 seprate tubes from a larger voltage.
Old 04-27-2023, 03:15 PM
Well if yours is good on 90v then 111v should be ok as well.
Old 04-27-2023, 02:53 PM
Yeah, that's some next level engineering.
