Old 07-20-2015, 12:39 PM
Zenith26kc20's Avatar
Zenith26kc20 Zenith26kc20 is online now
Look in the IF area for a capacitor you may have missed. The CTC9 has a small bumblebee that is only visible when the cover of the IF is removed. It'll cause sync troubles usually after warm up.
Old 07-20-2015, 12:42 PM
SwizzyMan's Avatar
Restoring an admiral c322
Yes flops on both sides and both on the signal generator and tv programming I cant even turn the knob a quarter turn without losing horizontal sync. I do apologize for any frustration I may be causing you Dave I am lucky that you are helping me out so much with this.
RCA CTC-7 Pensbury (Restored)
RCA CTC-5 Westcott (Restored)
Old 07-20-2015, 12:54 PM
good catch, an easy one to miss under the IF cover.
ALL bumble bees must be replaced. they are worse than wax paper caps.
Old 07-20-2015, 12:59 PM
SwizzyMan's Avatar
I did not see that one when I first took the cover off. Maybe it was replaced or maybe i missed it?
Old 07-20-2015, 01:19 PM
SwizzyMan's Avatar
Ok the bumblebee has been replaced with an elmenco cap. Are those prone to failure? should I replace it?
Old 07-20-2015, 01:32 PM
http://videokarma.org/attachment.php...9&d=1363626356
white thin cap right in the center
Old 07-20-2015, 01:36 PM
you have that new cap tester take it out and test it.
and yes white tube ceramic elmencos have been know to be problems, not like wax or bumblebee but enough that they should be suspected.
Old 07-20-2015, 01:43 PM
SwizzyMan's Avatar
How exactly did you get the shield off the back of the IF board? My soldering iron is not melting the solder joints holding it in.
Old 07-20-2015, 01:45 PM
look at the pic its not the bottom
Old 07-20-2015, 01:47 PM
SwizzyMan's Avatar
There is a metal shield on the trace side of the pcb blocking me from getting to the pcb traces so i can take out the cap.
Old 07-20-2015, 01:49 PM
solder iron, heat stake, lift cover. if solder iron not hot enough you need a bigger solder iron or clip from top and j hook in new.
Old 07-20-2015, 02:01 PM
SwizzyMan's Avatar
OK it is in. Anything else I should do before I shove it back in?
Old 07-20-2015, 02:06 PM
SwizzyMan's Avatar
Old cap was open at 400v. Hopefully the new one will solve my problem.
Old 07-20-2015, 02:28 PM
Open? it should be open (eye should completely open). Shorted or leaky at rated voltage is bad. Not sure how your eye tube tester works
did you check the value as well?
try testing the new one, do a video of the test of the old and the new.
Old 07-20-2015, 02:37 PM
SwizzyMan's Avatar
Open as in completely dead. On my tester when the eye closes and stays closed that indicates excessive leakage. The eye stayed closed at 400v for the old one. The new one tests no leakage at 400v with the eye staying open.
