Old 11-20-2016, 12:29 AM
Tech-Master NIB TV Kit #5516
Guys,
I won this 1955 TV kit NIB at an auction today. It does not come with a CRT.
The parts haven't even been removed from the carton! I talked to the seller and he said that he removed the instruction sheet to see what CRT it uses, but he didn't have that type. Otherwise completely unmolested. Because he already looked at the instruction sheet, I pulled them from the envelope.
What a find!
Of course the real question is should I keep it this way or build it?
Photobucket isn't cooperating so no pictures right now. I did post some pictures over on ARF.
Old 11-20-2016, 10:40 AM
Kevin Kuehn's Avatar
Workin' Late Again
I wouldn't have any reservations building that. Looks like any 70 degree electrostatic focus CRT could work, but I'm guessing that chassis is set up for a 17" tube, like a 17HP4.
Old 11-20-2016, 11:39 AM
Some pictures.
Old 11-20-2016, 11:41 AM
Kevin,
Thanks for the reply. I needed that info for a CRT! Where did you get it? Was it a page from an Allied Catalog or such?
Old 11-20-2016, 11:49 AM
I also think it uses a magnetic focused CRT. There is a fly-back transformer and the schematic shows a HV lead going to a 2nd anode on the CRT.
I think the ad has a typo.
Old 11-20-2016, 12:18 PM
Workin' Late Again
The listing is from my 1956 Burstein Applebee Co. Radio Master catalog.
Magnetically deflected, but electrostatic focus, unless your kit came with a electromagnetic focus coil? Your build manual must share some information on compatible picture tubes?
Old 11-20-2016, 05:56 PM
Get new caps instead of using the wax caps that came with it, also use new electrolytics too.
Be careful, it looks like a hot chassis set.
And be sure that the CRT you use has the same heater current as that of the heater string.
Old 11-20-2016, 10:33 PM
It's a low B+ hot chassis design, similar to the AC-DC Emerson set I just restored.
The CRT used would be a 17HP4, 20HP4 or a 21YP4. I would stick with the 17HP4 type, as the design is a slightly lower high voltage supply, intended for smaller screen sets.
I see it uses the tried and true synchro-guide horizontal circuit.
All the CRT's at the time were 600 ma, 6.3volt heaters.
Old 11-20-2016, 11:52 PM
Yeah, I checked the specs and a 19QP4 is a 12K CRT. That would be a good one too...right?
Old 11-21-2016, 10:45 AM
Isn't the 19QP4 a Dumont type round tube?
The number is not familiar to me and I've seen a lot of old TV's, but not real many Dumonts.
Unless you meant, 14QP4?
Old 11-21-2016, 11:18 AM
No, it is not a round tube.
Old 11-20-2016, 11:50 PM
Will do on all counts. Thanks
Old 11-23-2016, 01:36 PM
benman94's Avatar
benman94 benman94 is offline
Resident Lunatic
I've found that the 17, 20, and 21 inch tubes that specify a minimum ultor voltage will usually work WELL below the minimum recommended; a slight twist of the brightness control will usually suffice. Hell, my Philco 48-1000 refuses to put out more than about 6.5 kV, but the 10BP4 in it still shows a nice watchable, if not terribly bright, picture.
Old 11-23-2016, 01:46 PM
Workin' Late Again
I agree, although I believe there becomes more of a focus issue as the deflection angle increases.
Old 11-27-2016, 08:18 PM
I checked my Riders index and they cover the 5516! The index lists 18-3 and 21-13. I have Riders for TV vol. 2 thru 12. IIRC Tech-Master 630 chassis is covered in volume 4. Riders included not only the electrical but also mechanical info. Screw sizes etc. I'm thinking that maybe this information would also be included for my 5516 chassis.
Does anybody have these volumes and could you check to see what Riders shows? It would be really appreciated if I could get a copy of those pages.
Thanks.
