Does this smear (left set) show up when the color is all the way off? Hard for me to tell from the photo if its in the luminance, but I'm guessing it is.
If I had to guess without further investigation, I'd suspect the IF alignment around the video carrier. A non-symmectrical Nyquist slope can do this kind of thing. To do some diagnostics, turn the chroma all the way down. If it's still there, see what happens when you change the fine tuning. If it gets wider and narrower as you turn the fine tuning left and right, it may be alignment. The pic on the right set seems to have a bit of a ghost to the right of objects, which could be a bit of delay line ringing. Again, these are only guesses without exploring further. |
We had a textbook alignment curve after completing alignment. We have put on about 125 hours on the set since restoration one year ago. Stuff drifts, etc.
If you watch the video, the shadows only appear occasionally. This scene is the worst.
I will do some testing on Saturday. Preparing for an all nighter with the live Royal Wedding.
Well, I've caused enough trouble for today - going to get ready for bed.
| Audiokarma |
I think that if the image were any smaller, one would be unable to see just how well the image on the set has been restored.
I never would have believed there could be an image this good from a 15G. |
The 21CT55 (CTC-2B/CTC-3[they gave the convergence board it's own CTC#]) uses a 21AXP22. The RCA CT-100 (CTC-2 plain) uses a 15GP22. I should know; I've (somehow) got an example both models, the chassis are side by side on my bench.
https://visions4netjournal.com/2018/...-carousel-5083
I’ve posted shots of “Kiss Me Kate”, “Ferris Bueller’s Day off”, “Gone With The Wind”, “The Red Shoes”, “The Wizard Of Oz” and “Gentlemen Prefer Blondes” and videos from the 21CT55 at this link.
https://visions4netjournal.com/2018/03/07/movie/ Here is Ferris and girlfriend in 1500X1000. The above link has them in 6000X4000. ![]()
You can see what Wayne is talking about with DC restoration. In the first photo, the letterbox band at the top is black, but at the bottom it is blue. In the second photo, her hair is normal but too blue at the bottom of the screen.
I hadn’t noticed this until Wayne brought it up. The first thing will be some testing and a tube exchange.
| Audiokarma |
On the other hand, I would expect to see a blue push at the bottom of this shot of Jane Russell’s dress. The problem if it exists, is hard to see from movie to movie and scene to scene.
What you need to see the problem is a letterboxed program or something with similar characteristics.
Agree.
Whoa! Look at Tournament of Roses Parade #2, at 01:26 and following, and 01:58 and following. In these scenes, much of the background is neutral pavement. In the 21CT55 there is a 60 Hz blue hum bar moving slowly upward. The CTC-5 also has a hum bar, but it's weaker and different.
Some portion of these effects could be caused by a beat between the TV video and your camera sensor, but I don't see how your camera could cause two different effects on the two sets like that. It seems like there's some hum in the color circuits or the blue matrix/amplifier, which sometimes makes the bottom bluer and sometimes not. The DC restorer *might* be able to take out hum, but then again maybe not, if the time constants are long. Besides checking DC restorer operation, maybe you should be looking for the hum. |
Here are the frames Wayne noticed. ![]()
| Audiokarma |
