Old 08-09-2023, 03:54 PM
That “flashing” is most likely due to the DVM being disrupted by the horizontal pulses on that line, an analog meter would not do that.
I'm wondering if the flashing is either the peaks that it can't sample & display
properly, or that he is measuring DC, and the meter is seeing that sign wave
(or what it thinks is an AC component and it's alerting the driver that there
is a curve in the road). At one point I was going to ask Timmy to put his
meter on AC & see if it would read some of those signals (scope screen
shots with the P-P signals on it) But not sure what would happen) I
gotta try it one day - I was thinking since he don't have a scope
the meter may give a P-P reading on the signal. You know
there was an old fart at the shop I worked at & although
we had 2 scopes, he did all his work with a meter &
a pencil shaped signal injector and a hand held
audio amplifier with a detector diode you
could switch in or out..... No matter the
circuit he would poke that thing on it
and listen, if he was working on Vert.
he listened for 60hz, if it was horiz
he listened for the whistle. No
HV stuff or course.....
Just goes to show, you can
always find what you need
if you get a little inventive....
As cranky as Augie was,
he was pretty cool &
Smart.....
Old 08-09-2023, 04:17 PM
I did have an old CONAR Model 255 oscilloscope that I was willing to give to him for the price of shipping, but he turned it down
it would have come in handy right now.
I gave it to someone else :/
Old 08-09-2023, 04:19 PM
Believe me if I still had all my color sets I would get a scope and learn how to use it but as hard as it is to diagnose these problems I won’t be getting one I have a lot of money into this set along with a spare crt and I just cannot justify spending anymore on this set unless it’s parts.
Old 08-09-2023, 04:42 PM
Would v6 have anything to do with this color issue because I have a resistor on pin 8 2.7meg but it’s up to 3.9meg , Searching for any other bad resistors.
Do the math it's 44.4% off, so unless there was a cheapo bin for 44%
tolerance resistors, & ok'd for use in that set, that one is out of spec.....
Of course replacing it won't fix it...... Just being the depressed
robot from Hitchhikers Guide to the Galaxy.....
This set can be fixed without a scope.... I'm not too sure I would
worry about switched wires on the flyback either, remember
it was working as it's currently wired.....
Old 08-09-2023, 05:23 PM
I had tried the new xtal and I had got color lock but it only had mostly red but I couldn’t adjust the oscillator because it was stuck and cracked so I’m going to put the new xtal back in and do the afc procedure and see what results I get being I can adjust the oscillator coil now.
Old 08-10-2023, 08:57 AM
With the new xtal the colors are alittle more organized but still not there the picture on the screen looks like a really bad purity setup
Old 08-10-2023, 09:05 AM
Using the color gen the stripes have different colors from top to bottom with the new xtal the old xtal the color bars are moving and distorted
Old 08-10-2023, 09:18 AM
post pix plz.
Old 08-10-2023, 09:27 AM
If you have an email I can send it to you I can’t put any pics on here it wants me to resize and each time it won’t accept it I have been trying but I won’t go
Old 08-10-2023, 09:40 AM
mine is [email protected]
Old 08-10-2023, 10:20 AM
Closer to the correct freq, but still no lock.
http://suzaku.live-evil.org/IMG_1027.JPG
http://suzaku.live-evil.org/IMG_1029.JPG
http://suzaku.live-evil.org/IMG_1028.JPG
Also, the color shown (rainbow bars) look very faint, should be much more pronounced, as you saw on my pics. Not sure if the burst amp has something to work with there, if color is turned all up, and that's as strong as is shows, that could be part of the problem.
Old 08-10-2023, 10:39 AM
So is this looking like the oscillator
Old 08-10-2023, 10:43 AM
Not sure if I'm following what the pics are showing.
If the color distortion is stationary but different in different parts of the screen it's not a color lock problem; more like a CRT purity problem.
Old 08-10-2023, 10:46 AM
Looks like the purity's severely off. Has there ever been a set-up and/or degaussing been done to the set? (I haven't read back thru the whole thread)
Old 08-10-2023, 11:03 AM
So I degaussed and got a picture but looks like the blue is missing could only get a picture with the new xtal the old one I couldn’t do I’m assuming the old xtal was bad but the blue no color adjustments were done
