Old 02-11-2013, 08:27 PM
oh yes that is just temp to work out the design. prob make it from copper as its easy to work and solder together.
Old 02-11-2013, 11:03 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
one more the obligatory Dorthy close up...
Man, check out those ruby-red lips..... that's friggin awesome, Dave! Did you already do an alignment?
Charlie Trahan
Old 02-12-2013, 08:18 AM
Nope to the alignment, I only touched up the chroma matrix using a vectorscope. before that the greens were either brown or blue. It only took a minor tweak but it made all the difference in the world.
I do plan to put the BK 415 on it soon to see if I can get the pic a bit sharper.
I have another CTC-5 that uses the super chassis, has a different chroma chassis that I will also be working on. It also has a 21AXP22 so it should be interesting to see them side by side.
Old 07-16-2013, 07:08 PM
here is a link to the completed Wingate.
http://www.youtube.com/watch?v=FlJ0mmAFU-8
http://www.youtube.com/watch?v=awBdl94wvbk
I just found the correct pull knobs for the missing lowers, and thanks to Steve, I have an idea about the escutcheon need. I am going to see if I can find an oversized escutcheon (brass with squar hole) the file to the correct shape as its a very simple shape so I am pretty sure I can get it very close.
Old 07-17-2013, 10:50 AM
Steve D.'s Avatar
Steve D. Steve D. is offline
Dave,
You should post the photo of the lower Wingate door pulls I sent you. Someone out there may have a complete set from a junked Wingate. Who knows?
-Steve D.
Old 07-17-2013, 11:10 AM
Thanks Steve,
here is what I am looking for. The pulls rings I have found on ebay, but the small backplate is missing from my set
Old 07-17-2013, 11:15 AM
funny thing about that video of the wizard of oz, on my other sets I have the same issue with the tint range, you have to advance it much more toward green to get normal pictures. With other video sources the tint range is much more normal. I don't recall having issues with other DVDs so I assume its not the player but rather the DVD itself. odd....
Old 07-17-2013, 07:06 PM
ohohyodafarted's Avatar
Bob Galanter
Here you go. Available on ebay.
http://compare.ebay.com/like/2207251...Types&var=sbar
ME http://AntiqueTvGuy.com
Old 07-17-2013, 07:16 PM
http://www.ebay.com/itm/200298858825...84.m1497.l2649
this is what I found, maybe that key you linked is two part and I could use the backplate.
On Bob's link I asked them if its two pieces, and if so to get a pic of just the back plate. The pull part I found looks to be identical to the orig. I may just fab up the back plate based on Steve's pic as it does not seem to have any ornate decoration.
Old 07-18-2013, 01:07 PM
A while back, there was a discussion with comparison pictures of various Wizard Of Oz disc versions, and their hues varied quite a bit. If you don't have the newest version that was released a couple of years ago, it might look better than older ones. It certainly looks fantastic on Blu-ray.
Old 07-07-2014, 08:04 PM
Steve D.'s Avatar
Posted in error……….
