Old 06-26-2008, 11:59 AM
kx250rider's Avatar
REAL TVs have TUBES!
Beautiful job on that remote!
Charles
Old 06-26-2008, 02:54 PM
Old 06-27-2008, 04:40 AM
Adam's Avatar
Adam Adam is offline
Removed the safety glass, cleaned all the dirt/dust off the front of the crt and the inside of the glass, and put that strip that says "color" back where it should be.
Old 06-27-2008, 07:23 AM
batterymaker's Avatar
Repro Battery Builder
Which VS battery number does it take? Chances are it's a VS133, and there's an alkaline equivalent called the En133. Eveready recently stopped making them, but there's a cottage industry making them. Just check on the web.
Old 06-27-2008, 11:53 AM
kx250rider's Avatar
Looks great! Did you have to battle with that black goo? Every time I try to get that RCA safety glass clean, I have thousands of spots of that black sealer goo everywhere from the carpet, doorknobs, faucets, up my nose, and Goodness knows where else!
Charles
Old 07-01-2008, 08:03 PM
eberts eberts is offline
1961 Ctc-10
Old 07-04-2008, 12:36 PM
Adam's Avatar
pictures of the chassis:
Old 07-04-2008, 06:19 PM
fsjonsey's Avatar
fsjonsey fsjonsey is offline
Living The Draper Ethos
This looks alot like the set President Kennedy had in the Oval Office.
Old 07-05-2008, 04:16 AM
Adam's Avatar
I think it is the same model set, apparently installed by Eisenhower: http://www.eisenhower.archives.gov/a...l/Oval_Office/
Originally Posted by kx250rider View Post
Looks great! Did you have to battle with that black goo? Charles
No black goo, someone had been in there to clean it out before me (but long enough ago for lots of dust to build up since). I can tell for sure because they also dented that aluminum piece on top that holds the glass in prying it out. (otherwise the cabinet is in nearly like new condition)
The battery is VS163 Eveready E163, I looked around no 4.2v batteries, but there may be some 4.5v batteries that might work (or if I can find 3 small enough 1.5v batteries).
After taking a good look at the chassis I can see a lot of repairs done before (mainly caps replaced). Also whoever worked on it before kept hitting wires with the soldering iron, melting the insulation in places, not so bad I want to replace them, but still I would have thought he would have been more careful on such a high-end set. That big replacement electrolytic on top of the chassis there, 80mfd 450v, is not actually replacing one of the power supply filters, but rather the 50mfd 50v cap which hooks to the contrast control, I wonder if he really meant to do that or just connected the wrong wire. The thermistor was broken and the wires were just twisted together there.
Was there originally some kind of metal cover that went over the bottom of the IF board? It looks like there might have been something like that there that was unsoldered and never replaced.
Old 07-05-2008, 04:49 PM
fsjonsey's Avatar
There are a few 4.5v button cells out there that you could get to work.
Old 07-05-2008, 07:22 PM
Old 07-06-2008, 01:05 AM
I read the White House was in disrepair, and falling apart. When Kennedy moved in, Jackie with her magic, made them spend millions to rehab, restore, and decorate the place. They were not too thrilled with her spending that kind of money, she wanted
and got the best material and craftsmen to do the work.
Today they are glad she did that, restored dignity to the White House. Maybe she had the TV tossed out ?
Old 07-06-2008, 05:18 AM
Adam's Avatar
There is a series of pictures here: http://www.whitehousemuseum.org/west...ce-history.htm It looks like Kennedy kept the ctc-10, but Johnson had a unit installed that was 3 sets in one console.
The remote does actually turn the tint, color, and volume controls.
I checked all the tubes. None shorted, or so weak that they obviously won't work. The 6AQ5 (audio output) was weak enough that I'll probably swap it out, and the 6EM7 (vertical) was slightly weak, but I'll probably see if there's actually any vertical trouble before changing it. Most of the tubes had been changed in this set over the years, it probably saw at least 10 years or so of service, many tubes have that more modern looking RCA logo on them. It is interesting to note that all the replacement tubes are RCA tubes, I think this is the first time I've ever seen anyone actually pay attention to the signs they put on stuff that say "use only ... tubes."
Old 07-06-2008, 01:09 PM
kx250rider's Avatar
Yes. It had a metal plate with holes to reach through to get at the IF slugs. You need that cover in place or the alignment will be interfered with by stray magnetic fields elsewhere in the chassis. If nobody comes up with an extra one, you could make a temporary one with an old paint thinner can, etc.
Charles
Old 08-10-2008, 02:20 PM
Adam's Avatar
I'm nearly ready to put this set back together. I swapped all the electrolytics and paper caps in the TV chassis. I replaced the broken thermistor. Checked the restistance readings at the tube sockets in the horiz and vert circuits following the sams, and only changed a few resistors that were only around 20% off anyway. I swapped that one 6AQ5 audio output tube, all the other tubes tested ok. This set looks to me like it was well maintained into the late 60s or even into the 70s, there were already some orange drops in it, as well as many tubes with that newer RCA logo. I also recapped the remote chassis, and replaced the selenium rectifier that was in there with a 1N4007 diode. It's strange how the plating is starting to come off of the top of the remote chassis. And I swapped the selenium rectifier on the convergence board for 3 diodes. The 3 things I haven't picked up yet for this set are still a battery for the remote, the metal piece that goes under the IF board, and the socket for the light that goes on the bottom of the cabinet (it was missing). But I might just put it back together and fire it up first, just to see what's going on.
