Old 07-26-2007, 04:10 AM
Adam's Avatar
Adam Adam is offline
Rca 721ts
This is the next set I'm starting to work on. Pictures are after I cleaned up the chassis a bit, it was full of lint. The insulation is bad on the wires going to the yoke and the volume on/off switch. The plastic piece which goes inbetween the neck of the crt and the focus coil was totally disintegrated. Otherwise everything looks ok. I do have the cover to the hv cage and all the knobs.
