Old 08-29-2007, 08:29 PM
jln1966 jln1966 is offline
When I was a kid we had a set just like that. This was in the early 70s. Oure didnt have the legs on it. It sat right on the floor. It broke down a few times and my dad would tinker with and get it working again. He finally got tired of messing with it and got rid of it,probably about 73 or 74. It sat in the back of an old store building he owned for several yaers and then it finally got tossed. It would be nice to have it back now.
Old 08-29-2007, 08:50 PM
Originally Posted by radio63 View Post
I have a Westcott and they are neat sets. I was noticing the legs on this one, they seem much shorter than the legs on my set. (Maybe a different production run?) The legs on my set are gold colored like on this set but are tapered getting more slender toward bottom. The legs on this set appear to be shorter and thicker...unles it's just me or an optical illusion. No big deal, this is a great set. Congratulations on getting it!
Gilbert
They are shorter than the picture in the brochure - don't know if they could be substitutes.
Old 08-29-2007, 09:31 PM
Here's a quick look in the back. I thought the flyback cover was gone - turns out it was stuck beside the chassis along with the screens from the bottom openings. For some reason, I didn't hear them bouncing around when it was carried in.
Can anyone tell me where the date code would be on this "Colorama" tube? Hidden under the yoke or cover perhaps?
Old 08-29-2007, 11:21 PM
Old_tv_nut-
I am going to be repairing a CTC-5 that I got from another AK member recently, and it does not have the flyback cover. Could you take a few pictures of just the cover for me while yours is off? I will need to make one for mine. Thanks for your help.
Old 08-30-2007, 08:55 AM
Here are views from each edge, and being installed - looks like it needs a long screw to fasten at the near left corner as viewed here.
Old 08-30-2007, 02:43 PM
bluenorm
Guest
Posts: n/a
Hi I see the cover from here.
Old 08-30-2007, 04:39 PM
Thank you! I really appreciate the pictures. "14 views"-it looks like others have wanted to see them as well.
Old 08-30-2007, 07:24 PM
Dan Starnes's Avatar
Gizmo Nut
Just found this post,, very very nice set indeed!
Dan
Old 09-07-2007, 09:33 PM
Now for a littlle cold water - just drove 60 mi and back to borrow the CRT tester from DRH, and found out I shouldn't have bothered because the heater is open. (measures 180k ohms, actually - don't know where that is coming from). NO visible heaters when the tester is attached.
Has the tube gone to air? I can't tell - doesn't spark or anything when the tester is applied, but I suppose the tester voltage may be too low to do that.
Does anyone know if anyone is rebuilding metal cone 21AXP22A CRTs? (And is it worth bothering if it went to air, in case it has an air leak at the face seal?)
Tried knocking on the base a bit with no results. Anyone with experience that some other treatment (e.g. heating the pins?) might have success?
Anyhow, unless I could find a CRT, working on the rest of the set is not such a rush job anymore.
Old 09-07-2007, 09:50 PM
I'm sorry to hear that, truly a bummer.
You could try heating the pins and dabbing a little solder on the ends so it wicks into the pin, I'm doubtful though in this case.
How hard is it to remove the yoke?
The getter is somewhere in that area, usually a ring of clear glass on the neck with the getter showing through.
Old 09-07-2007, 11:03 PM
ohohyodafarted's Avatar
Bob Galanter
Yes by all means try soldering the heater pins. I have had at least a couple of bad solder joints on the filiment pins. Heat it up with a 100 watt iron and let it suck some solder into the tip of the pin. If the original solder connection was marginal, it is possible that the heat of the tube combined with the heavy current of 3 filiments going through the pins, may have caused the solder joint to fail.
Hawkeye can rebuild it if it is under vacuum. He can not guarantee that it will be a success, because sometimes a metal tube will crack the face of the tube during the rebuilding. That said, another AK member has had Hawkeye do a successful rebuild of a 21axp22 and was very pleased with the results. I believe the cost is about $350 plus shipping.
Good luck and let us know what you find. Hope it has not gone to air.
ME http://AntiqueTvGuy.com
Old 09-07-2007, 11:15 PM
John Marinello's Avatar
<-- "Byron"
If the getter flash still appears mirror-like, then the tube is certainly under vacuum. If it's milky-colored and is flaking off, then the tube is garbage.
Old 09-08-2007, 12:36 AM
I'm sorry to hear this news-the fact it is not infinity could be reason to have hope. Let us know how you do with pin resoldering, etc.
Old 09-08-2007, 02:17 AM
Old 09-08-2007, 02:46 AM
disco disco is offline
It sounds like you have a high resistance connection in the base. On several occasions I had to remove the base and re-tin the oxidated leads. Fred
