Old 11-05-2007, 09:37 PM
Bill Cahill's Avatar
Super Moderator
Tried it again. Now B+ is even lower. Whatever is wrong, it has gotten worse.
I'll have to start disconnecting circuits to find the problem 5U4 was getting most un happy.
Bill Cahill
Please join my forum.
Old 11-06-2007, 06:40 PM
Hi Bill
I haven't done much with my 6T72 since the spring. I too have some health issues that have slowed me down a bit. In the spring I started fooling with my Ford Falcon but now it's getting colder it's tv and radio time. Best I remember I had a picture and sound but no sync. Also still need to order those .018 and .047@1kv caps to complete the recapping. I know it's got a few bad resistors in the sweep circuit so I'll have to look at that again. Btw I managed to unscrew one of the tuner osc adj screws, are they a pain to get back in?
Good luck with your sleeping I know how it is being tired all the time. I suffer with cronic lyme disease and a few bad discs...
Terry
ps. I've been dittiling with a little Motorola VT-71 and got it going a few days ago.
pss. I was thinking about your problem. I remember that my set shorted one of the new filter caps out as soon as fired it up for the first time. I'm pretty sure I wired it correctly. I did note that it seems that the power supply runs some of those caps right to the limit like 450v +. My line is about 122v.
Old 11-06-2007, 10:53 PM
Super Moderator
Smile
You need to install a 25 watt resistor between the first filter, and the rectifier.
Set is supposed to run at 370 volts on rectifier. It's running hot. If you leave it this way, other circuits will break down.
This set was originally designed for 117 volts ac maximum.
Thanks.
Bill Cahill
Old 11-21-2007, 05:54 PM
Hi Bill
Mine is up and running. Found a small mica in the horiz osc that was leaky (C-148 82pf) Once that was replaced it started working but not enough vertical to fill the screen. Measured voltages everthing looked good so I swapped the audio and vertical output tubes and that fixed it. How's yours coming along?
Terry
