Old 01-21-2004, 05:30 AM
Why I think RCA no longer makes ColorTrak TVs
RCA's ColorTrak system for picture and color control is no more--at least they don't use the term any longer for whatever system replaced it, if any. Here's why I think they don't use the ColorTrak control system anymore.
When RCA's ColorTrak system was first introduced (in the '70s), color TV transmission was not nearly as tightly controlled at the transmitter as it is today. The result was the picture on viewers' sets would sometimes appear off-color on older sets, requiring the viewer to readjust the tint and/or color controls at least once during a program. RCA's ColorTrak (and other manufacturers' answers to it, such as Zenith's Automatic Tint Guard [ATG] and later Color Sentry, Magnavox's Chromatone, et al.) put an end to this constant readjustment, because the system constantly monitored the color signal from the station and corrected the color and/or tint as necessary. Remember RCA's advertising pitch for ColorTrak? " . . . grabs it, aligns it, refines it (the color TV signal) and locks the color on track."
Today's TV stations transmit a very high-quality signal from computer-controlled transmitters and studios, not to mention the satellite feeds from the networks, so the pictures on our TVs today from network stations, especially on cable (I think the latest figures show some 80 percent of American homes are now receiving TV programming either via cable or satellite) is so good (because of the very tight controls over signal quality) that the need for automatic control circuits in individual receivers is nowhere near as pressing now as it was in ColorTrak's heyday. Today's sets, all but the very inexpensive ones, have some sort of automatic color control which can be enabled or disabled, as desired or needed, via an on-screen menu selection (e. g. my 1999 RCA XL-100 has a menu option on the "Picture Quality" onscreen menu which allows for enabling or disabling the automatic color function). These auto-color controls keep things like flesh tones (which are among the most important and difficult to reproduce colors in a color TV picture) from drifting off to pink, green or some other ghastly color; even though the system is no longer referred to as ColorTrak by RCA, the auto-color control in today's RCAs performs the same function as the earlier system.
There are other differences between today's color control systems and RCA's original ColorTrak, such as the fact that ColorTrak (and Magnavox's Videomatic and VideoEye, the former being an automatic brightness/contrast control, with the photocell beneath the CRT, the latter being an extension of that which used the photocell to control color fidelity, saturation, etc. in the company's high-end color sets as well) used a photocell directly under the CRT to sense changes in room lighting, as did some GE portables in the late '50s (today's sets do not have this feature) and possibly still others as well. However, as I said, with the color quality being tightly controlled at the transmitter and in the studio (not necessarily in that order), by the time the signal gets to your antenna or cable system, the "grabbing, aligning, refining" once done by RCA's ColorTrak and other systems at the set has already been taken care of by the TV station or network, so all that shows on viewers' sets is a pleasing color picture, with little or no adjustment of controls necessary. This is probably why the color, contrast and other controls (except, of course, for channel selection, power on/off, and volume control) in modern TVs are now located (hidden, really, until they are invoked by the menu button on the TV set or remote) on the onscreen menus, rather than on the front of the set.
I do not adjust to change easily, but this is one change I am glad to see. Television receivers have finally become what they should have been from the beginning, IMO--set-and-forget instruments in which all the viewer has to do anymore is sit in front of the set, pick up the remote, push the power button, select the channel he/she wants to watch--and then simply sit back and enjoy the show. No more worrying about picture quality. General Sarnoff would have been proud. Now, if Hollywood would get on the stick and start producing decent TV programming . . .
