Old 02-14-2008, 07:59 AM
Old1625's Avatar
Old1625 Old1625 is offline
If the "wiggle" you mention moves along slowly in a wave action along the side of the raster then you've got some 120Hz feeding into the horizontal sweep circuit--a sure sign of a bad 'lytic somewhere in the power supply.
If the raster is narrower at the top or bottom--keystone-shaped--then the yoke is suspect.
Another member here was going around in circles over weak HT in an old Zenith, and discovered that the new flyback he put in was the cause. Swapping it out again fixed it.
Old 02-14-2008, 06:47 PM
nasadowsk's Avatar
Damn does run fast…
I can turn the wiggle up and down in speed by adjusting the vert hold. I think I probed all the B+ lines, but I'll check 'em again - it'd sure be nice for this to be a simple power supply issue!
No keystone, thankfully...
As far as the flyback? This one's original. Maybe it is bad, but I'm not sure of a good way to test it...
Old 02-18-2008, 10:34 PM
nasadowsk's Avatar
Damn does run fast…
Well...figured it out.
It's the flyback
What's weird is it reads open on the DMM, but it still kinda makes HV. I'm not sure how that works - maybe it arcs over?
Anyway, I'll have to hunt one down. So far, the Sam's lists the subs:
Stancor A-8117
Chicago TFB-1
FWIW, the Maggie # is 320026-1
Looks like a '630 one, but I'm sure they all did back then :/
Old 02-21-2008, 07:19 PM
cbenham's Avatar
cbenham cbenham is offline
[QUOTE=nasadowsk;1663625]Well...figured it out.
It's the flyback So far, the Sam's lists the subs:
Stancor A-8117
Chicago TFB-1
It's also a Thordarson FLY-1.
The Sams sub may be wrong; my Stancor book crosses the Magnavox number to A-8127 and this matches to a Fly-1 and an RCA 211T3.
Best,
Cliff
Old 02-22-2008, 02:17 AM
yagosaga's Avatar
yagosaga yagosaga is offline
VK Member
It's the flyback
Are you sure?
- Eckhard
Old 02-24-2008, 04:37 PM
nasadowsk's Avatar
Damn does run fast…
Originally Posted by yagosaga View Post
Are you sure?
- Eckhard
Yeah. The open HV wnding seems to be a good hint that it's bad (I tried poking down a little, maybe I'll unwind a layer tomorrow and see if the break's on the surface...)
Old 02-24-2008, 05:40 PM
nasadowsk's Avatar
Damn does run fast…
Are you sure?
- Eckhard
