Old 02-26-2008, 12:25 PM
M3-SRT8's Avatar
M3-SRT8 M3-SRT8 is offline
Originally Posted by tubesrule View Post
You would think so based on the components, but with a serial number of 030360 I would think this is a later chassis?
Darryl
Yeah, I was going to ask you what the S.N. was. The Chassis S.N. all begin with "C", regardless of what Model it was (?)
I'm told the Single Top Brass Clip signifies an early production 630TS. Keyed AGC came mid production (?) and some, like mine (serial number unknown) has both.
LJB
Old 02-26-2008, 02:18 PM
Old1625's Avatar
Old1625 Old1625 is offline
Originally Posted by M3-SRT8 View Post
Yeah, that Chassis looks like mine. I can barely see the "Golden Voice" Label on the corner of the Wooden Cabinet's floor, so, that goes where it always goes. Notice the Black Hi Voltage Cage. That's like mine. Earlier ones were Dark Bronze, I believe.
Looks like they just omitted the "Eyewitness" Label, and put a Serial Number Tag there instead. Christ, and Barbara, My GF, spent soooo much time repro'ing it.
LJB
Uhmmm...begging your pardon, but isn't that RCA tm "Golden Throat" ....?
Old 02-26-2008, 02:39 PM
If you ever get mad at that 630 & decide that it MUST leave, I'd love to give it a home where it'd be loved, petted, played with 'n' called "George"...An' I ain't too persnickety about the decals, Golden Throats, Deep Throats, none o' that...(grin)
Old 02-26-2008, 03:03 PM
Darryl
Darryl, I have serial #30300, with some 17000 odd 621's thrown in to the mix I would think 30,000 would be a fairly early production set.
I have a picture of a 630 with a serial in the 10,000 range and have been told of a 621 in the 20,000's.
I've been told the "C" stands for the Camden N.J. plant.
M3-SRT8's Avatar
But, She is already getting all that attention, and more. It would be like giving away a member of the Family.
Every square inch was restored. I can't let Her go.
I'm looking for a Playmate for Her...Any Suggestions on a next TV Project?
LJB
PS: Christ, I have it Bad...
Old 02-26-2008, 03:04 PM
M3-SRT8's Avatar
Yup...I misspoke.
LJB
Old 02-26-2008, 03:11 PM
Go for it...Gitchoo a Fifties color set & give it "The Treatment"...
Old 02-26-2008, 04:39 PM
Old1625's Avatar
The Abominable Snowman! Memories.....
Old 02-26-2008, 05:10 PM
M3-SRT8's Avatar
"Gosh...It's Hot !"
A.S.
Old 02-26-2008, 05:15 PM
M3-SRT8's Avatar
OK, I found this picture I grabbed from eBay a long time ago, it has the tag next to the resistor box where you have the Eyewitness tag.
This set doesn't have an eyewitness tag so perhaps it was located on the back instead of the chassis?
The 8-T-243 and the T-120 have both the Golden Throat and the Eyewitness tags glued to the back, someone here or at the ARF must have an original 630 back they could check.
Edit, my 630 has the Eyewitness tag in the same location as yours but it has the serial tag in the normal spot, I don't have a back, what does it mean, I haven't a clue, I'm totally confused now...
Maybe the AGC sets got the other tags on the back instead of the chassis.
It makes sense, from a Warranty standpoint, that the Serial Number Label should be to the right of the Resistor Cover, ON the Chassis itself, and NOT on the (removable & potentially swappable) Resistor Cover. I'll make up a fresh Serial Number Label, and put it on the Chassis, to the Right of the black cover. On AGC Sets, looks like NO "EyeWitness" Label appeared anywhere on the Chassis.
...unless, SOMEONE out there has a pic of one.
LJB
Old 02-26-2008, 06:11 PM
tubesrule's Avatar
tubesrule tubesrule is offline
Thanks for the info Eric. 30,000 seemed like a high serial number, but if this run included the 621, then it is kind of low. Interesting that our sets are only 60 apart!
BTW, very nice job on the restoration LJB.
Darryl
Old 02-26-2008, 09:41 PM
M3-SRT8's Avatar
Thanks, Darryl.
LJB
Old 02-27-2008, 12:13 AM
621TS seems like the ideal companion. Even prettier, takes up less space, and the electronics should hold no mysteries after this project.
You may already have read about Hugo Holden's 621 remanufacturing project on the ETF website.
http://www.earlytelevision.org/holden_621.html
Going to those lengths is not to my taste, but there's a lot of good information in that article.
A 621 will cost more upfront than a 630, but if you pay yourself $1 per hour during the restoration, you can earn back that investment in no time :-)
Good job on this project. If you run out of things to do, you can finish my incomplete RCA CTC-11 color roundie, which has been languishing on the workbench.
Phil's Old Radios
Old 02-27-2008, 04:22 AM
M3-SRT8's Avatar
Phil's Old Radios
Yup. A 621TS would be nice. If you know of a good restoration candidate, let me know.
By The Way, both You and Hugo Holden were the inspiration for my Project. As you can see from the finished resto, I closely followed both of your work.
Thanks!
LJB
Old 02-29-2008, 06:04 AM
M3-SRT8's Avatar
Ummmm. I have an RCA T-100 in the cellar with an "A" before the serial Number. Built in Camden, NJ.
The Prefixes must stand for something else.
LJB
