Old 07-05-2008, 03:46 AM
myrgatroyd myrgatroyd is offline
In Germany FM was initialized in ´49. There was an international meeting in Genova which ruled the bandwith a transmitting station could use and what frequency ranges could be used for civil broadcasting.
Unfortunately they defined the space for one broadcasting station very small, so that two senders often messed up each other (9 khz-"piping"). So you had two possibilities: The directional ferrite antenna, (Richtantenne oder Peilantenne, the knob under your volume control), or to weaken the reception, hoping the disturbing second sender will be faded out.
That´s the problem for am.
A weakened FM reception is seldom. Perhaps some radios had problems receiving a sender that blasted to strong.
The tuning sectors of that old beasts are often very sensitiv because of long distances between the transmitting stations.
I used to listen AFN Frankfurt on FM with an old tube set. None of my other receivers were able to fish that weak signal.
Yours
Alex
Old 07-06-2008, 08:06 PM
solidjackson solidjackson is offline
Oh, so I guess it's like a crude MPX system. Where this radio is sitting, hitting that button wipes out the signal completely. Everything works on this radio but, I noticed one of the 6BQ5 plates is running red... a bad capacitor or a short perhaps?
Old 07-08-2008, 06:28 PM
gadget73's Avatar
gadget73 gadget73 is offline
Or a bad resistor on the cathode circuit perhaps. Something is definitely causing the plate current to be too high though.
Random bits of stuff in the collection:
Yamaha YP-D4 turntable with B&O MMC 10E cart
Allied 495 receiver
2 Magnavox amps, AMP150 and an AMP178, currently under the knife.
Onkyo TX-4500
Onkyo Radian III speakers
Old 07-10-2008, 07:08 AM
You should check the currents around that valve. By the way you should recap that ole beast at the points with high currents and tensions. This is:
Filter caps (should always be changed)
The cap that couples one system of EABC 80 to EL84 (pre stage to last stage)
Caps that rule the current and the tensions to the plates
Cannot explain better because of my english.
But remember: Your gear is over 50 years old, and some caps (especially those sealed with tar or those little nasty beasts printed with WIMA should be changed without hesitating. They are known to be down after all this years.)
I strongly advice you to do that. You don´t want your house to be set on fire cause of a 5´column german radio?
Seriously: You are messing around with high currents, and the siemens is very easy to recap. It hasn´t got many of them, and you have a lot of place under the chassis. Also you have the whole documentation. That´s worth a lot. If you need help with the german expressions I would be glad to help you. Good luck!
Schatulle means a little box used to store jewels and treasure. That´s what you got. So take good care of your baby.
Yours
Alex
Old 07-10-2008, 08:19 AM
jeffsod jeffsod is offline
Very good advice there Alex!
Old 07-11-2008, 04:15 AM
In the last years I got ca 20 radios from this aera, and only two of them worked correct. The others had problems with their caps.
ERO, Hydra and WIMA can be thrown out without checking them. They are simply bad.
That is my experience.
Old 07-11-2008, 05:37 AM
Uhh-Huh. Couldn't say it better myself...
Old 07-11-2008, 08:03 AM
Thank you, Jeff and Sandy... there are so many mistakes to be made, why make always the same ones? That would be boring.... grin.
Old 07-22-2008, 12:15 PM
Thanks for all the replies. Fortunately (or unfortunately) no capacitors seem to have the markings like WIMA... most of them have the Siemens logo and are relatively small by mid-50s standards. One of the electrolytics on the 6BQ5 was off by about 20uf, so that isn't a good sign.
Old 07-29-2008, 03:48 AM
Those tar-sealed praline´s and wax-sealed bonbons tend to get dry. So they short the circuit or don´t allow any current to pass (in extremes). Check them out. No matter what the marking is.
That cap you checked shurely is not the only one working out of tolerance...
