Old 01-12-2009, 10:54 PM
WISCOJIM WISCOJIM is offline
Originally Posted by ohohyodafarted View Post
There are two terminal strips in this yoke. I used 5 minute epoxy and clamps to glue the terminal strips to the inside surface of the edge strip. (thumbnail 10)
Great job Bob!
Could you share with us the name of and where you got those clamps you used? I've never seen those before, but they look like they could be handy for many small projects.
Could you also share with us the item numbers for the Evergreen styrene sheets you ordered? I searched the Walther's site and they gave me over 1,900 choices for Evergreen styrene sheets.
And thanks for sharing with once again.
Old 01-13-2009, 11:11 AM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
Excellent work! Perhaps you can devise a way to do the B&W Yoke covers with the centering magnets attached to them?
It's a big problem on the RCA 8" portables, they distort badly and the magnets are only held on by a small rolled over lip.
I'm having that exact problem with my 8" RCA right now. It started pulling in from the right side. I thought it was the horizontal output tube but it wasn't. One of the centering rings had slipped off of the yoke cover because it is warped. I can't find a new yoke so I am trying to buy a complete set to salvage for parts. So far, that's the only weakness I've found with these sets. Rebuilt yoke covers for this model may become about as sought after as the rubber masks on the 7" Motorolas.
Old 01-13-2009, 12:53 PM
ohohyodafarted's Avatar
Bob Galanter
OK Jim, here you go
Go to Walthers.com
Evergreen black styrene sheets
.080" stock number 269-9117
.040" stock number 269-9115
Plastistruct 3 ounce bottle of bonding cement solvent
Stock number 570-2
Good Luck!
Bob
ME http://AntiqueTvGuy.com
Old 01-13-2009, 12:56 PM
Bob Galanter
I don't know what the yoke looks like for the 8 inch RCA. Could someone please post a couple of GOOD photographs so I can evaluate the issue. Perhaps I can devise a method to rebuild them.
Here is a link to Kant-twist clamps For this project I used the 1 inch size.
http://www.amazon.com/s/?ie=UTF8&key...l_67lni58w5i_e
I am not a fan of small screen sets so as a result my knowledge in this area is next to nothing.
Bob
Old 01-13-2009, 08:09 PM
Bob
Thanks Bob. That Styrene and those clamps may come in handy for more than just yoke repairs.
Old 01-13-2009, 09:45 PM
Bob, here are some pics of the RCA 8" yoke cover.
Note the notches, the yoke is clamped in place by a pivoting fork type thing, the notches are there so the yoke can be adjusted with a screwdriver, same with the notches on the magnet rings.
We could get by without the notches, it would just make it a little more difficult to rotate the yoke, putting the magnets on the cover might be a bit harder, there is a wave washer between them to keep them from rotating too easily, I'm thinking they would have to be put in place then the plastic hot rolled over them?
Old 01-13-2009, 11:32 PM
Bob Galanter
I think the front side looks do-able. Not easy, however do-able. It would probably be necessary to machine a PVC or Styrene insert with a flange lip to slip the magnet rings onto and then insert the assembly into the hole in the center of the cover while fusing it onto the styrene. Certainly a lot more involved than a conventional yoke cover, but with a lathe and a mill you can make almost anything.
How do the latch tabs on the back edge relate to the part they mate with? Do the tabs simply latch behind the body that the cover slips over, or do the latchs hook into some sort of notch? I guess a photo of how the latch tabs relate to the mating part would be in order.
Bob
Old 01-13-2009, 11:35 PM
Fantastic project work, Bob. I will keep your notes handy if I have to do a restoration like yours.
Old 01-14-2009, 12:16 AM
The tabs snap on to the phenolic board on the back of the yoke.
A replacement wouldn't necessarily have to snap on, it could be glued with some Silicone but there would have to be some tabs or else a recess for the yoke to fit into and keep it centered.
Old 01-14-2009, 11:11 AM
compucat's Avatar
1949 Motorola 9VT1
8" RCA Yoke Cover
I would definitely be willing to pay for a replacement yoke cover for this model. It is a common model of high build quality so there will certainly be a need for these yoke covers.
Old 01-14-2009, 11:25 AM
Plumberboy1 Plumberboy1 is offline
I see this is about repairing TV's. I really did not read it all. I thought you might like to know I saw a unbuilt Heathkit color TV kit on the Bay for auction.
Greg
Old 01-14-2009, 12:40 PM
http://cgi.ebay.com/HEATHKIT-GR-2000...3A1%7C294%3A50
Old 01-14-2009, 05:17 PM
Thats the one. That would sure be a butt load of soldering! LOL
