Old 02-03-2009, 09:34 PM
Originally Posted by wa2ise View Post
I wouldn't write it off just yet, it can sound actually quite good on nearby strong AM stations. Most AM radios filter out audio reception above 5KHz, because of excessively narrow IF strips. But this radio has only two tuned circuits, and should allow the reception of the full 10KHz audio AM stations broadcast. Yes, AM radio channel separation is 10KHz, but not in the same market. AM stations use 20KHz of spectrum, for double sideband AM. The station 10KHz away from your local flamethrower will be extremely weak, and in a radio like this, not audible.
The volume control in sets like this are actually a combination of variable antenna loading, and RF stage gain (as a cathode resistor). The wiper is ground, one end goes to the antenna input, the other to the RF tube cathode. Turn the volume down, you are increasing the loading on the antenna, reducing the signal the RF tube is seeing, and also the gain of that tube also drops as the cathode resistance goes up. A lot of creative innovation went into the design of cheap radios!
Where this radio will NOT excel is as a DX machine. It's strictly a local station receiver.
I'm surprised it works at all. I just took a look at the underside of the chassis; looks as if someone cut out most of the components.
This one may (and probably should) pick up some of the more common 50kW stations at night, such as KYW, WBZ, WLS-AM, WABC, WCBS, etc. in the east and KABC, KCBS, et al. if within 50 miles or so of Los Angeles, among others--I've heard the big 50kW east-coast powerhouses here in northern Ohio after dark, using nothing fancier than a cheap 6-transistor portable radio with a loopstick antenna.
However, I do agree that a radio with this simple circuit (not much better than a glorified crystal set) would fail miserably if one were trying to snag a 0.5-kW station in, say, Kansas while he/she was in Ohio, even if the radio were attached to a 50-foot outdoor wire. I once owned a Zenith integrated stereo system with an AM tuner probably not much better than the one being discussed here. It was so bad it wouldn't pick up anything other than local stations in the daytime, and even some of those weren't readable depending on weather (I was about 15 miles from Cleveland at the time); at night I was hearing SW broadcasts in the middle of the broadcast band.
I wouldn't be surprised if whomever built the radio we are discussing took his or her cues from Zenith of Korea or Taiwan (!), as the set looks as cheaply built as the AM tuner in my stereo system must have been. The digital AM/FM tuner in my present bookshelf stereo isn't much better; it picks up one local 1kW (0.5kW nights) AM station 5 miles from here at 560 and 1460 kHz, 0.9 MHz apart. The station's assigned frequency is 1460 kHz. The FM tuner is not that bad, but not excellent either. I am some 40 miles from Cleveland's FM stations; this tuner won't get any of them in stereo using a standard T-dipole antenna. I bought a Terk tower AM/FM antenna which works better, but when using the amplifier, I have to be careful not to run the gain control too high, or else it overloads the tuner something terrible--even in this moderate signal area just beyond the suburbs of Cleveland.
BTW, when did you move to Seattle? I ask because I looked at your listing on the Buckmaster ham radio callsign server today and found that WA2ISE is still listed as being in Oradell, New Jersey. Did you move west just recently?
Old 02-03-2009, 09:59 PM
Bob E.'s Avatar
Bob E. Bob E. is offline
VK Member
Originally Posted by jonboy55 View Post
I have to make this even scarier.
This was the bulb in the lamp holder when I got the radio.
Hah! I have a 1937 Magnavox 78 RPM table-top phono that has one of those in the pilot light socket...green bulb through a red/orange lens??? I haven't plugged it in yet to see the sickly glow...
That's too funny, jonboy, now you have to restore the unit!
--Bob
Old 02-03-2009, 10:11 PM
I've seen similar looking 120V bulbs used as the dial lamp in '40's and '50's radios with selenium rectifier based power supplies.
Old 02-03-2009, 10:12 PM
Not a good set for DX ?!? I was gonna offer to swap my EK-07 or one of the R-3XXs on it.... Seriously, I've found that a LOT of these seemingly "dead" otherwise less-than-stellar sets come alive if you give 'em a halfway decent antenna...I took my KIWA MW Loop over to a bud's house one Sunday after, he had a late '30s catherdral that he'd re-capped, changed a few tubes in, done eveything by the book, but it was still deaf as a hammer. We hooked the KIWA up to it, & it CAME ALIVE...Little one & two lunger local-service daytimers from way up in Virginia & Kentucky bloomed...It was amazing. I wouldn't let him keep my KIWA, but he did run a line from his house about 75' to a tree. His set sings fine now...
Old 02-03-2009, 10:27 PM
David Roper's Avatar
console lover
Invariably C6 bulbs were in an 8-lamp string. They were designed to operate at 14-15 volts.
Old 02-03-2009, 10:55 PM
I'm just here in Seattle on a short term job assignment, which will end next month. Then I'll be back to NJ.
Sounds like FM tuners I had back in the 70's. Ones with bipolar transistor FM RF amp stages in the front end. In one I changed the bipolar to an FET, and got the overload problems under control (when you're 14 miles line of sight from NYC's Empire State Building, where all the FM stations transmit from, you get a lot of signal). Though I later heard that I could have done the same thing just by increasing the current thru the bipolar instead.
I had several strings of these lights, and I usually added more bulbs to the strings to drop the voltage seen by each bulb. Or use a rectifier diode to make the line voltage "look like" 85V instead of 120V (half power, which is not the same as half voltage if the resistance is the same. It's V^2/R=power, and 85^2 = (120^2)/2
