Old 03-13-2009, 01:54 PM
radotvguy radotvguy is offline
mike g
looks similar to the chassis i am working on
Old 03-13-2009, 03:36 PM
Bill Cahill's Avatar
Super Moderator
Smile
Spent alot of time adjusting the audio I F, and, Det. stages. It's noticebly louder, but, still nothing to brag about.
Picture, however, looks quite good.
I will fool with it a bit more, then, put it together.... Then, I'll try it on original tube.
Bill Cahill
Please join my forum.
Old 03-13-2009, 05:48 PM
gadget73's Avatar
gadget73 gadget73 is offline
Cool, glad to hear you finally got that sucker working. I'm sure you felt good after seeing a workable stable picture on that set after all the effort you've put into it.
Random bits of stuff in the collection:
Yamaha YP-D4 turntable with B&O MMC 10E cart
Allied 495 receiver
2 Magnavox amps, AMP150 and an AMP178, currently under the knife.
Onkyo TX-4500
Onkyo Radian III speakers
Old 03-23-2009, 07:21 PM
Super Moderator
Post
Well, last week on the bench tv was playing great, except for some slight horizintal fold over in the picture.
So, I put it in the cabinet, put everything together, hooked up my crummy hd converted box, and, brought it up on variac.
After much fiddling around, I had a nice, bright full picture with horiz. fold over.
I adjusted set. Got box to receive some stations.
I noted ch 3 oscilator on tv needs more tuning.
I decided to try a different horizontal output tube, of the correct no of course.
Started back up on variac.
Just as I was getting to operating voltage, I heard a very loud hum in the speaker, a grunt from power transformer, and, a loud pop out of chassis. I watched as dim video faded to a white dot. I shut it down.
Back to square one.
Bill Cahill
Old 06-15-2009, 12:12 PM
Super Moderator
Smile
Well, heree it is. The tv is about finnished, and, back in it's cabinet.
Let me show you some pictures of it playing. Some picture adjustment issues yet, but, it's working reliably. It plays quite well, actually. What do you guys thinik?
I copied my photobucket links from ARF.
"Kelloggs, the best to you each morning, brings you Huckleberry Hound!"
"...Don't let yourself forget. Tune up your tv set for Huckleberry Hound. That oh, so merry, chuckleberry, Huckleberry Hound.
Huckleberry Hound.............."
Bill Cahill
Old 06-15-2009, 11:02 PM
Tubejunke's Avatar
My similar RCA (TC-127) has always had a sound issue. Basically, I have to turn the volume wide open in order to hear the set across the room. When I did the recap a year or more ago I remember not being able to find any bad components, so I put it back together hoping that a different audio output tube or something would straighten things up. Since then I have replaced all of the audio tubes and nothing helps. Perhaps there is a resistor or something that I missed. I hate this because this TV playes PERFECTLY other than this one problem.
Any other ideas or pointers would be great!
Old 06-15-2009, 11:14 PM
Super Moderator
Post
I'm afraid that problem has me stumped also.
I get fairly good volume all the way up, but, slight decrease in control, means major decrease in audio volume.
I've replaced micas, tubes, spkr., which had also been blown, resistors, and, checked voltages, which appear to be proper.
Vol. control appears good.
No shorts, just not performing well.
I'll look at that problem more when I get back on vertical, and, horiz. osc. issues.
Other than that, set has been completely stable.
Bill Cahill
Old 06-17-2009, 06:59 PM
I have an Admiral with low volume. I changed out the 6SQ7 1st audio for a 6SN7 and add another stage. Works great now. I think your RCA uses a 6AV6 1st audio you may want to try a 6J6.
Terry
Old 06-17-2009, 07:14 PM
Super Moderator
Post
No, thanks. The ampolifier isn't the problem. It's something in the i f 's.
Bill Cahill
Old 06-17-2009, 07:55 PM
It looks great. Nice work.
